Can't find the MAF table anywhere in ECUFLASH
Old Aug 19, 2009, 07:56 PM
LIGHTSPD's Avatar
Can't find the MAFF table in ECUFLASH at all. Has anyone done the disassembly so I can add this in. Or for that matter even just know the address where it is located I can do the rest.
Cheers
Old Aug 19, 2009, 08:04 PM
xPRimNT's Avatar
Cam?
Enjoy
GSR (I don't have the MR one, but I'm sure it's here somewhere)
Evo10base.xml
Code:
    <scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="5" inc="1" storagetype="uint16" endian="big"/>
    <table name="MAF Compensation" category="Fuel" type="2D" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/>
    </table>
    <table name="MAF Compensation #2" category="Fuel" type="2D" level="1" scaling="AirFlow16">
    </table>
    <table name="MAF Compensation #3" category="Fuel" type="2D" level="1" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="50" scaling="MAFVoltScaling"/>
    </table>
52680015.xml
Code:
    <table name="MAF Compensation" address="5753a">
        <table name="X" address="615ea"/>
    </table>
    <table name="MAF Compensation #2" address="5758a">
        <table name="X" address="6163a"/>
    </table>
    <table name="MAF Compensation #3" address="575da">
        <table name="X" address="6168a"/>
    </table>
Old Aug 19, 2009, 08:20 PM
LIGHTSPD's Avatar
Thanks man tuning a large turbo X and was having trouble with Cobb and P codes so I thought I would give this a go.
Old Aug 19, 2009, 08:24 PM
LIGHTSPD's Avatar
Thanks for those how about the MAP sensor calibration tables. Or even better yet does someone have a dissassembly thye would like to share.
Old Aug 19, 2009, 10:36 PM
xPRimNT's Avatar
Sorry, don't have those ones! Good luck though.
Old Dec 10, 2009, 03:15 AM
TJung's Avatar
Will it work on Evo 9? Maybe someone has to Evo 9 this settings ?
Old Dec 10, 2009, 06:53 PM
mrfred's Avatar
Back when I was fiddling with Evo 10 disassem, I could not find a link between the code and the MAF table. I only found it by virtue of knowing what it should look like. There's probably an indirect reference to it. Maybe tephra has since traced it out.
Old Dec 10, 2009, 09:36 PM
HB Speed's Avatar
cam drop me a PM i can help you with that
Old Dec 11, 2009, 11:22 AM
Oracle1's Avatar
after adding bigger turbo, which parameters need tuning to avoid CEL?
I think the error code is related to airflow, I gues too much of it.
Any ideas, help please.
Old Dec 11, 2009, 12:02 PM
Clipse3GT's Avatar
Torque and Airflow limit tables...
Old Dec 11, 2009, 03:17 PM
Oracle1's Avatar
what should it be increased to?
Any examples?
Old Dec 13, 2009, 05:20 AM
kozmic27's Avatar
Any examples?
My torque and airflow tables on the stock turbo are up over 30% from stock. This 30% is roughly the same as the power increase the car is making over stock.
Old Dec 13, 2009, 01:18 PM
boostin20's Avatar
sub'd
Bob_tm
Jan 5, 2018 04:45 AM
redSLed
Jan 2, 2018 12:04 PM
Raceghost
Nov 23, 2016 10:17 PM
bevolucion
Jul 9, 2010 02:23 PM
mrfred
Apr 1, 2009 05:00 PM
Quick Reply: Can't find the MAF table anywhere in ECUFLASH
