54070007
54060007 and 54070007 below: (and thank mrfred)
<rom>
<romid>
<xmlid>54060007</xmlid>
<internalidaddress>5002a</internalidaddress>
<internalidhex>54060007</internalidhex>
<make>Mitsubishi</make>
<market>Puerto Rico</market>
<model>Lancer</model>
<submodel>Evolution X</submodel>
<transmission>5MT</transmission>
<year>2009</year>
<flashmethod>mitsucan</flashmethod>
<memmodel>M32186F8</memmodel>
<checksummodule>mitsucan</checksummodule>
</romid>
<include>evo10base</include>
<!-- <include>52680015_mods</include> -->
<!-- **Timing** -->
<table name="High Octane Timing Map" address="55957">
<table name="Load" address="60fd6"/>
<table name="RPM" address="60fa2"/>
</table>
<table name="Low Octane Timing Map" address="55b59">
</table>
<table name="Ignition Warmup Retard" address="5b8f1">
</table>
<table name="Unknown Timing Advance" address="57301">
<table name="Load" address="61580"/>
<table name="RPM" address="61566"/>
</table>
<table name="MIVEC Intake Normal Coolant Temp" address="5db69">
<table name="Load" address="615e4"/>
<table name="RPM" address="61614"/>
</table>
<table name="MIVEC Intake Low Coolant Temp" address="5dd69">
</table>
<table name="MIVEC Intake Map Interpolation" address="5e366">
<table name="Coolant Temperature" address="62464"/>
</table>
<table name="MIVEC Exhaust Normal Coolant Temp" address="5df69">
</table>
<table name="MIVEC Exhaust Low Coolant Temp" address="5e169">
</table>
<table name="MIVEC Exhaust Map Interpolation" address="5e374">
</table>
<!-- **Fuel Control** -->
<table name="High Octane Fuel Map" address="55027">
<table name="Load" address="60f5c"/>
<table name="RPM" address="60f36"/>
</table>
<table name="Low Octane Fuel Map" address="552d7">
</table>
<table name="Max Rich AFR Clip vs Coolant Temp" address="5a1dc">
<table name="Coolant Temperature" address="5d2dc"/>
</table>
<table name="Fuel Injector Scaling" address="536cc"/>
<table name="Injector Battery Voltage Latency Compensation" address="556d0">
<table name="Battery Voltage" address="60eb2"/>
</table>
<table name="Cranking Enrichment IPW Adder (Main)" address="574e6">
<table name="Coolant Temperature" address="6107e"/>
</table>
<table name="Cranking Enrichment IPW Adder (Unused)" address="56af0">
</table>
<table name="MAF Scaling Part 1" address="57586">
<table name="Volts" address="6164a"/>
</table>
<table name="MAF Scaling Part 2" address="575de">
<table name="Volts" address="616a2"/>
</table>
<table name="MAF Scaling Part 3" address="57636">
<table name="Volts" address="616fa"/>
</table>
<table name="MAP Mass Air Flow Scaling #1" address="604a0">
<table name="MAP" address="62a90"/>
<table name="RPM" address="62a64"/>
</table>
<table name="MAP Mass Air Flow Scaling #2" address="601c4">
</table>
<table name="MAP Mass Air Flow Scaling #3" address="5fee8">
</table>
<table name="Open Loop Load High Octane #1" address="57514">
<table name="RPM" address="60dc2"/>
</table>
<table name="Open Loop Load Low Octane #1" address="555da">
</table>
<table name="Open Loop Load High Octane #2" address="574fc">
</table>
<table name="Open Loop Load Low Octane #2" address="555c2">
</table>
<!-- **Turbo Control** -->
<table name="Boost Control Load Offset" address="53484"/>
<table name="Boost Target Engine Load #1A (High Gear Range)" address="58e8d">
<table name="Throttle" address="62672"/>
<table name="RPM" address="625f0"/>
</table>
<table name="Boost Target Engine Load #1B (High Gear Range)" address="58f37">
</table>
<table name="Boost Target Engine Load #2 (Low Gear Range)" address="5743d">
</table>
<table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58d39">
</table>
<table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58de3">
</table>
<table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="57393">
</table>
<table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/>
<table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="54696"/>
<table name="Reactive Solenoid Turbo Boost Error Correction" address="58d20">
<table name="Load Error" address="6261a"/>
</table>
<table name="Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58d12">
<table name="TPS" address="6265a"/>
</table>
<table name="Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/>
<table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a212">
</table>
<table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a228">
</table>
<table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a23e">
</table>
<table name="Boost Control RPM Per MPH Xover (Gear Based)" address="54686"/>
<table name="Boost Limit" address="555b4">
<table name="RPM" address="615ba"/>
</table>
<table name="Boost Cut Delay Timer" address="53068"/>
<!-- **Throttle Control** -->
<!-- **Limits** -->
<table name="Stationary Rev Limit" address="5468c"/>
<table name="Max Speed for Stationary Rev Limit" address="5468a"/>
<table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" address="5468e"/>
<table name="Rev Limiter" address="5305e"/>
<table name="Speed Limiter" address="53062"/>
<table name="Airflow Check #1" address="5e995">
<table name="Throttle" address="624f0"/>
<table name="RPM" address="624c8"/>
</table>
<table name="Airflow Check #2" address="5ea8b">
</table>
<table name="Airflow Check #3" address="5eb81">
</table>
<table name="Airflow Check #4" address="5ec8b">
<table name="TPS-Related" address="62538"/>
<table name="RPM" address="62512"/>
</table>
<table name="Airflow Check Offset" address="60ad5">
<table name="TPS-Related" address="62abc"/>
<table name="Reactive Solenoid BWGDC-Related" address="62ad4"/>
</table>
<table name="Torque Limiter #1" address="6386d">
</table>
<table name="Torque Limiter #2" address="63963">
</table>
<table name="Torque Limiter #3" address="63a59">
</table>
<table name="Torque Limiter #4" address="63b4f">
</table>
<!-- **Knock Detection** -->
<!-- **IDLE** -->
<!-- **Misc** -->
<table name="ECU ID" address="5002A" type="1D" scaling="ECU ID"/>
<!-- *** OBD-II *** -->
<!-- *** MUT *** -->
<table name="MUT Table" address="3ef80">
<table name="X"/>
<table name="Y"/>
</table>
</rom>
<rom>
<romid>
<xmlid>54070007</xmlid>
<internalidhex>54070007</internalidhex>
<submodel>Evolution 10 MR</submodel>
<transmission>SST</transmission>
<year>2009</year>
</romid>
<!-- <include>54070007_mods</include> -->
<!-- **Timing** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **Limits** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **IDLE** -->
<!-- **Misc** -->
<table name="MUT Table" address="3f040">
<table name="X"/>
<table name="Y"/>
</table>
</rom>
<rom>
<romid>
<year>2009</year>
</romid>
<!-- **Timing** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **Limits** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **IDLE** -->
<!-- **Misc** -->
<table name="X"/>
<table name="Y"/>
</table>
</rom>
<rom>
<romid>
<year>2009</year>
</romid>
<!-- **Timing** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **Limits** -->
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<!-- **IDLE** -->
<!-- **Misc** -->
<table name="X"/>
<table name="Y"/>
</table>
</rom>
Yes, copy and paste everything he put for your rom up there and put it in a file named 54070007.xml
This:
This:
Code:
<rom> <romid> <xmlid>54070007</xmlid> <internalidaddress>5002a</internalidaddress> <internalidhex>54070007</internalidhex> <make>Mitsubishi</make> <market>Puerto Rico</market> <model>Lancer</model> <submodel>Evolution 10 MR</submodel> <transmission>SST</transmission> <year>2009</year> <flashmethod>mitsucan</flashmethod> <memmodel>M32186F8</memmodel> <checksummodule>mitsucan</checksummodule> </romid> <include>evo10base</include> <!-- <include>54070007_mods</include> --> <!-- **Timing** --> <table name="High Octane Timing Map" address="55957"> <table name="Load" address="60fd6"/> <table name="RPM" address="60fa2"/> </table> <table name="Low Octane Timing Map" address="55b59"> <table name="Load" address="60fd6"/> <table name="RPM" address="60fa2"/> </table> <table name="Ignition Warmup Retard" address="5b8f1"> <table name="Load" address="60fd6"/> <table name="RPM" address="60fa2"/> </table> <table name="Unknown Timing Advance" address="57301"> <table name="Load" address="61580"/> <table name="RPM" address="61566"/> </table> <table name="MIVEC Intake Normal Coolant Temp" address="5db69"> <table name="Load" address="615e4"/> <table name="RPM" address="61614"/> </table> <table name="MIVEC Intake Low Coolant Temp" address="5dd69"> <table name="Load" address="615e4"/> <table name="RPM" address="61614"/> </table> <table name="MIVEC Intake Map Interpolation" address="5e366"> <table name="Coolant Temperature" address="62464"/> </table> <table name="MIVEC Exhaust Normal Coolant Temp" address="5df69"> <table name="Load" address="615e4"/> <table name="RPM" address="61614"/> </table> <table name="MIVEC Exhaust Low Coolant Temp" address="5e169"> <table name="Load" address="615e4"/> <table name="RPM" address="61614"/> </table> <table name="MIVEC Exhaust Map Interpolation" address="5e374"> <table name="Coolant Temperature" address="62464"/> </table> <!-- **Fuel Control** --> <table name="High Octane Fuel Map" address="55027"> <table name="Load" address="60f5c"/> <table name="RPM" address="60f36"/> </table> <table name="Low Octane Fuel Map" address="552d7"> <table name="Load" address="60f5c"/> <table name="RPM" address="60f36"/> </table> <table name="Max Rich AFR Clip vs Coolant Temp" address="5a1dc"> <table name="Coolant Temperature" address="5d2dc"/> </table> <table name="Fuel Injector Scaling" address="536cc"/> <table name="Injector Battery Voltage Latency Compensation" address="556d0"> <table name="Battery Voltage" address="60eb2"/> </table> <table name="Cranking Enrichment IPW Adder (Main)" address="574e6"> <table name="Coolant Temperature" address="6107e"/> </table> <table name="Cranking Enrichment IPW Adder (Unused)" address="56af0"> <table name="Coolant Temperature" address="6107e"/> </table> <table name="MAF Scaling Part 1" address="57586"> <table name="Volts" address="6164a"/> </table> <table name="MAF Scaling Part 2" address="575de"> <table name="Volts" address="616a2"/> </table> <table name="MAF Scaling Part 3" address="57636"> <table name="Volts" address="616fa"/> </table> <table name="MAP Mass Air Flow Scaling #1" address="604a0"> <table name="MAP" address="62a90"/> <table name="RPM" address="62a64"/> </table> <table name="MAP Mass Air Flow Scaling #2" address="601c4"> <table name="MAP" address="62a90"/> <table name="RPM" address="62a64"/> </table> <table name="MAP Mass Air Flow Scaling #3" address="5fee8"> <table name="MAP" address="62a90"/> <table name="RPM" address="62a64"/> </table> <table name="Open Loop Load High Octane #1" address="57514"> <table name="RPM" address="60dc2"/> </table> <table name="Open Loop Load Low Octane #1" address="555da"> <table name="RPM" address="60dc2"/> </table> <table name="Open Loop Load High Octane #2" address="574fc"> <table name="RPM" address="60dc2"/> </table> <table name="Open Loop Load Low Octane #2" address="555c2"> <table name="RPM" address="60dc2"/> </table> <!-- **Turbo Control** --> <table name="Boost Control Load Offset" address="53484"/> <table name="Boost Target Engine Load #1A (High Gear Range)" address="58e8d"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Boost Target Engine Load #1B (High Gear Range)" address="58f37"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Boost Target Engine Load #2 (Low Gear Range)" address="5743d"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58d39"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58de3"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="57393"> <table name="Throttle" address="62672"/> <table name="RPM" address="625f0"/> </table> <table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/> <table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="54696"/> <table name="Reactive Solenoid Turbo Boost Error Correction" address="58d20"> <table name="Load Error" address="6261a"/> </table> <table name="Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58d12"> <table name="TPS" address="6265a"/> </table> <table name="Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/> <table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a212"> <table name="RPM" address="625f0"/> </table> <table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a228"> <table name="RPM" address="625f0"/> </table> <table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a23e"> <table name="RPM" address="625f0"/> </table> <table name="Boost Control RPM Per MPH Xover (Gear Based)" address="54686"/> <table name="Boost Limit" address="555b4"> <table name="RPM" address="615ba"/> </table> <table name="Boost Cut Delay Timer" address="53068"/> <!-- **Throttle Control** --> <!-- **Limits** --> <table name="Stationary Rev Limit" address="5468c"/> <table name="Max Speed for Stationary Rev Limit" address="5468a"/> <table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" address="5468e"/> <table name="Rev Limiter" address="5305e"/> <table name="Speed Limiter" address="53062"/> <table name="Airflow Check #1" address="5e995"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Airflow Check #2" address="5ea8b"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Airflow Check #3" address="5eb81"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Airflow Check #4" address="5ec8b"> <table name="TPS-Related" address="62538"/> <table name="RPM" address="62512"/> </table> <table name="Airflow Check Offset" address="60ad5"> <table name="TPS-Related" address="62abc"/> <table name="Reactive Solenoid BWGDC-Related" address="62ad4"/> </table> <table name="Torque Limiter #1" address="6386d"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Torque Limiter #2" address="63963"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Torque Limiter #3" address="63a59"> <table name="Throttle" address="624f0"/> <table name="RPM" address="624c8"/> </table> <table name="Torque Limiter #4" address="63b4f"> <table name="TPS-Related" address="62538"/> <table name="RPM" address="62512"/> </table> <!-- **Knock Detection** --> <!-- **IDLE** --> <!-- **Misc** --> <table name="ECU ID" address="5002A" type="1D" scaling="ECU ID"/> <!-- *** OBD-II *** --> <!-- *** MUT *** --> <table name="MUT Table" address="3f040"> <table name="X"/> <table name="Y"/> </table> </rom>
