Grimspeed EBCS Testing
So I had a chance to test the new Grimspeed 3-port Electronic Boost Control Solenoid on a Evo X MR this weekend. I want to thank Smanders for all the new logs and the time for testing. Here are some logs to show how it well it works!
I think this unit works very well to plug right into the stock harness and be able to control boost from the stock ecu!
I haven't seen any 3 ports that have impressed me yet. I can hold similar boost to your post with just a GST boost pill accept after 7k where it falls to 18.5 at 7500rpm. But, with the right tune, you'll make more power by compensating mivec and timing after 6k rpm vs maxxing out the little turbo. I think 3 ports are more for those with bigger turbo's.
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Chris is right if you have a stock turbo it will be hard for it to hold big boost.....larger turbos like the red will have no problem at all
Chris I will probably be ordering one in a week or 2 and I think with the mods on my car it should be fun tuning I will so a base pulls and then do the install and get to tuning I know my tuner will be able to make the boost nice and smooth
shunderwunder
Jul 17, 2012 06:31 PM
maperformance
EvoX 'For Sale' Suspension / Brakes / Handling
33
Jan 17, 2012 08:07 PM
