(PICS) KNOCK when your LTFT's lean out...check it out
If you want to see knock here it is...once I had this knock happen feels like the car falls on it face or you are getting major clutch slippage. However look at the AFR from the AEM UEGO. CBRD is fixing my maps, not sure why this is happening.
Just want to show what real knock looks like... people start yelling wolf when they get 1-2 counts. Try 33-36 knock. Once you start getting 50-70 you are having serious problems.
Lean but no knock...
Lean knock....
Lean still knock...
Lean knock....
Lean still knock...
36 is max knock count. At least it was with Evo 8/9.
13.7 AFR is a bit extreme for -6 fuel trim. Have you checked you relay? Is this WOT?
- Bryan
- Bryan
If it was a real 30+ knock count you would hear it, and possibly see a rod in your rearview...
Well I would imagine the timing being pulled from the ECU thinking there is 36 knock counts would be substantial enough to make the car feel like it's falling on it's face. take a look at the timing log
