Newbie question on Wideband - why would you want/need one?
I did some reading, but it wasn't clear to me why I might want or need one. For example, if oyu are having your car tuned by someone else, and don't plan to do any tuning yourself, is it really only beneficial for monitoring purposes?
I assume any decent tuner uses a wideband to tune?
Sorry for the basic questions - I never used/investigated using one even on my previous car.
Yeah, you really don't need one if you don't plan on tuning your car yourself.. But you can use it kinda like a diagnostics tool if something goes wrong and your car is bucking or something..
That's what I kind of figured. I have the AMS downpipe which can take a wideband I think, so maybe I could easily do it at some point. Logging would be nice if something goes wrong so I could pull the data after the fact to see what happened.
You can also use it as a tool to see if something is going to go wrong. Like if you have a problem with an injector or part of the fuel system it will show the car leaning out, and you can realize this and fix it before it becomes a big problem.
So let me ask another dumb question - if I wanted to basically log all of the data from a wideband real-time, such as from the LC-1 or something similar, and analyze it at any point later what would I need.
Would I be able to have some device onboard that records the data continuously that I could at any time download and analyze on my laptop?
In general, you only log when you need to; e.g. while tuning, or maybe diagnosing a problem that's skewing your AFRs. Your AFR gauge is the most practical way of monitoring for anomalies while your not tuning.
I use the AEM UEGO and EvoScan (and sometimes PCMScan) for logging. The bare minimum needed to get started (besides the AFR sensor itself) is a laptop, a Tactrix cable ($169) and Evoscan ($25.) There are other details I'm leaving out here, but a quick search can net you most of what you need to know if you're interested in doing more than just basic monitoring. If you're interested I can point to a few good threads to get you started. HTH.
if you are running a non oem turbo and all supporting goodies it is a VERY good idea to see if you have a problem before your motor blows.. with out it the only way to know if you are running lean is to melt your pistions
alfredoaal
Oct 20, 2015 01:35 PM
Fastone_evo6
Jul 24, 2012 01:24 AM
AutoMotoSports
Automotosports - Illinois
37
Jan 21, 2010 09:11 AM
SwiftEVO
17
Jun 22, 2005 12:20 PM
