High IDC at 7k - stock turbo
Old Feb 9, 2010, 06:44 AM
  #136
tsitalon1's Avatar
Originally Posted by E6-X
is your formula for IDC in evoscan correct ? have a look at it . . .
It is, unless the IPW is incorrect in EvoScan....Who can tell me if the IPW is correct or not?
Old Feb 9, 2010, 07:29 AM
  #137
Whitewind's Avatar
IPW would have be off too.
IDC
[IPW]*3.90625*x/1200"
IPW
="x/1000"
So IDC comes from IPW.
In evoscan under Eval will say this.
x/1000
Old Feb 9, 2010, 09:40 AM
  #138
Whitewind's Avatar
Heres a pull from today.
File Type: zip
Old Feb 9, 2010, 09:48 AM
  #139
tsitalon1's Avatar
I'm sorry, I cannot read this
Old Feb 9, 2010, 10:09 AM
  #140
Whitewind's Avatar
Meaning??? You can't view or can't read it?
RPM/// PSI/// Timing/// Load/// IDC/// AFR
6500 /// 20.4899/// 12/// 217/// 92.1267/// 11.0838
This is MAX IDC I see.
@ 7100rpm its at 88% so drops little.
Old Feb 9, 2010, 10:13 AM
  #141
tsitalon1's Avatar
Ahh, that's better, just smashed together made it realy hard to read....So I am roughly 10-15% above yours... Not horrible but enough to be intresting...Thanks!
Old Feb 9, 2010, 10:43 AM
  #142
Whitewind's Avatar
Yours is like this
RPM///PSI///Timing///Load///IDC///AFR
6585///21///14/////223///103%///11
Man about ***** on the same besides IDC. Now I turn down a lot stuff for winter here on top end timing and my bottom end some but not a lot. same and try keep boost spikes down (I play in snow every once in awhile lol)
I know Im at 5000' but don't know if that has anything to do with it. I know if go south I will make more power so maybe you are topping them out...
Old Feb 9, 2010, 10:48 AM
  #143
tsitalon1's Avatar
See that is what I initially thought and everyone called me crazy....
As far as your altitude, doesn't your load also take into consideration altitude?
Meaning a load of 209 at 5000' is the same as a load of 209 at 300' right?
If load is the same and WBO2 readings are the same, what the hell is causing the higher IDC's?
However if altitude is considered AFTER the load, I can see how I am maxing them out...
I'm as confused as ever, but do know that larger injectors will at least allieviate the high IDC's
Oh, what is your target A/F in your tune for that rpm/load? I'm looking for disparity here....
Old Feb 9, 2010, 11:04 AM
  #144
GST Motorsports's Avatar
tsitalon,
I'll go through all my other logs once I get to my tuning laptop, but here is some data for you:
2008 Evo MR - GST Boost pill, TBE, HFC, drop-in filter, FMIC
6543 / 21 psi / 225 load / 98 IDC / 11.1 AFR
- Bryan
Old Feb 9, 2010, 11:07 AM
  #145
tsitalon1's Avatar
Originally Posted by GST Motorsports
tsitalon,
- Bryan
Bryan, I'll wait for your other examples, but this tell sme that NOTHING is wrong and I am simply overrunning the injectors.
Your load is the same as mine, not sure about timing, but from 98 to 103% IDC is close to me...time to buy injectors.. Do you concur?
Old Feb 9, 2010, 11:09 AM
  #146
Whitewind's Avatar
10.7-10.9 so about .2-.3 off.
Load is load should not matter. My turbo works a lot hard than guy does at sea level but load is load.
Old Feb 9, 2010, 11:11 AM
  #147
Yea it is looking like that is most likely the case. Evoscan reported IDC's usually have about a 10% buffer to them. I usually lose fuel control @ 105-110%.
On our dyno I usually max the injectors out around 310-315 whp on GSR's. Which is right about where the Evo 9's would max out the stock injectors as well. Keep in mind this is on 91 oct where timing is lower and AFR a little richer then 93 octane so the power is a little lower as well.
I'll get the other samples up once I get back in town, I am currently in Tahoe.
- Bryan
Old Feb 9, 2010, 11:33 AM
  #148
Whitewind's Avatar
You know not going lie, I seen one guy on the other forum have this happening and thought he was crazy too lol. But that is when I went did pull with my IDC (But was de-tuned at time and still am) seen was low 90% so was not worried about it. But even when I was running more timing and everything I never log IDC but I could still control my AFR so I did not worry about it.
Correct me if Im wrong guys but if you can still control your AFR (Not say MAFR is 10.0 AAFR is 11.5) why would you worry about IDC being little over 100% then. Seems me they are doing it well still. I understand if running into lean problems and cannot get your AFR richer and your IDC is 120-130% changing them out.
Old Feb 9, 2010, 11:55 AM
  #149
tsitalon1's Avatar
No your right, I am right on that edge. I can just barely control it. To me, 105% or so just isn't comfortable. Just preference I guess. I will buy some injectors soon (sorry pump purchase pushed this back a bit). While some people run high IDC daily, most injector manufacturers will state that you shouldn't go above 80% or so.
Think about the ECU safe guards. If the ecu senses knock it could try to lower timing AND add fuel. Hence the problem, can't add fuel when your injectors are maxed.
It's nice to know that my tuning experience and gut feelings are to be trusted At least in this case....
Old Feb 10, 2010, 08:11 AM
  #150
tsitalon1's Avatar
Hey guys,
I'll be ordering my injectors not to far from now, just want to make sure I don't order the wrong ones.
My goals are ~450whp with a BBX turbo, will DW1000cc be enough for 93 octane?
I believe they will, just dbl checking..
Quick Reply: High IDC at 7k - stock turbo
