Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
#81
The trigger would work the same, you just need to know the address of a memory location to trigger on. The 8's have an IC cooler sprayer button. The X has a cruise control button. I'm not sure what you could key off of for the 9. (Never driven one)
#86
EvoM Community Team
I'll try to build a cable when I get back from Deal's Gap this weekend.
#87
Does anyone know if it is possible to get the standalone logging to have a more precise time scale like in the Evoscan logs, i.e., LogEntrySeconds? I wired up my ECU ADC to my wideband and everything works great but Virtual Dyno cannot plot the run worth **** because the only time scale in the logs is <time> which doesn't provide a smooth graph at all due to the lack of resolution. It looks like a set of bear teeth when plotted.
Thanks!
Thanks!
#89
Yeah, it's probably due to logging too much stuff. The standalone does not log very fast. The drive could limit it too... I say could, because it's not writing that much data, so I don't know how fast it needs to be, but if the flash has to erase a sector, it could cause some good lag.
