Evo X ECU Bench Process
#33
guys i'm trying to benchflash / unlock a ecu with terrible ecutek tune but it seems that i'm doing something wrong in the process...
with the alternative flash box checked in the ecuflash options i can write and read (really slow) the stock rom that i'm trying to load to the ecu, but when i uncheck the box and try to flash the rom again as stated in the instructions, i still can't get into the ecu like its still locked or something....
[23:43:14.199] J2534 API Version: 04.04
[23:43:14.199] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[23:43:14.199] Device Firmware Version: 1.11.3157
[23:43:19.387] -- loading kernel --
[23:43:19.387] -- connecting to kernel --
[23:43:19.388] kernel get version
[23:43:20.204] interface close
[23:43:20.217] interface close
Help please...
Help please...
#34
[01:41:20.249] J2534 API Version: 04.04
[01:41:20.249] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[01:41:20.249] Device Firmware Version: 1.11.3157
[01:41:23.069] -- loading kernel --
[01:41:23.069] -- connecting to kernel --
[01:41:23.069] kernel get version
[01:41:23.397] ECU HW part number : 1860A981
[01:41:23.412] ECU SW part number : 1860A98101
[01:41:23.428] -- unlocking ECU --
[01:41:23.428] starting session...
[01:41:23.444] requesting seed...
[01:41:24.005] interface close
[01:41:24.021] interface close
#41
i'll make all the process again and post both logs in 2 hours
tephra thanx for your interest man
#45
I have had issues with tis too. I would flash the Alt and it was Successful, I would then flash it normally and it would be successful. I then take out the wires and plug the ECU back into the car and try to start it. The car will not start and its still stuck in programming mode. I hook up my laptop to see if I can re flash or read the ecu and it fails to connect? Any Ideas Tephra?
