Kill Immo..
Kill Immo..
Hello,
This is USDM EVO X 5speed.
I Tried to kill immo but could'n.
I saw some error message.
[17:36:01.015] EcuFlash Version 1.42.2595
[17:36:01.015] OS Version Windows XP
[17:36:01.015] Qt Version 4.5.0
[17:36:01.031] 56 memory models read.
[17:36:01.031] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:36:01.437] 590 ROM metadata models scanned.
[17:36:01.437] checksum module "subarudbw" loaded.
[17:36:01.437] checksum module "mitsucan" loaded.
[17:36:01.437] flashing tool "wrx02" loaded.
[17:36:01.437] flashing tool "wrx04" loaded.
[17:36:01.437] flashing tool "sti04" loaded.
[17:36:01.437] flashing tool "sti05" loaded.
[17:36:01.437] flashing tool "mitsukernel" loaded.
[17:36:01.437] flashing tool "mitsukernelocp" loaded.
[17:36:01.437] flashing tool "mitsubootloader" loaded.
[17:36:01.437] flashing tool "shbootmode" loaded.
[17:36:01.453] flashing tool "shaudmode" loaded.
[17:36:01.453] flashing tool "subarucan" loaded.
[17:36:01.453] flashing tool "mitsucan" loaded.
[17:36:14.125] 52680015 (92 tables) inheriting evo10base (102 tables)
[17:36:14.125] 52680018 (0 tables) inheriting 52680015 (102 tables)
[17:36:14.203] 1048576 byte image read.
[17:39:11.656] 1048576 byte image written.
[17:39:54.265] J2534 API Version: 04.04
[17:39:54.265] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[17:39:54.265] Device Firmware Version: 1.07.2597
[17:39:58.296] -- loading kernel --
[17:39:58.296] -- connecting to kernel --
[17:39:58.296] kernel get version
[17:39:58.625] ECU HW part number : 1860A979
[17:39:58.656] ECU SW part number : 1860A97902
[17:39:58.671] VIN : JA3AW86V58U047466
[17:39:58.671] -- unlocking ECU --
[17:39:58.671] starting session...
[17:39:58.953] requesting seed...
[17:39:58.953] sending key...
[17:39:59.296] -- uploading kernel --
[17:39:59.312] .
[17:39:59.328] .
[17:39:59.343] .
[17:39:59.359] .
[17:39:59.359] .
[17:39:59.375] .
[17:39:59.390] .
[17:39:59.406] .
[17:39:59.406] .
[17:39:59.421] .
[17:39:59.437] .
[17:39:59.453] .
[17:39:59.453] .
[17:39:59.468] .
[17:39:59.484] .
[17:39:59.500] .
[17:39:59.515] .
[17:39:59.515] .
[17:39:59.531] .
[17:39:59.546] .
[17:39:59.546] .
[17:39:59.546] -- connecting to kernel --
[17:39:59.546] kernel get version
[17:39:59.562] kernel version is : OpenECU Mitsubishi M32186 CAN Kernel V1.09
[17:39:59.562] reading kernel comm buffer size
[17:39:59.562] comm buffer size set to 1024
[17:39:59.562] reading kernel flash buffer size
[17:39:59.562] flash buffer size set to 4096
[17:39:59.562] -- flashing image to ECU memory --
[17:39:59.968] -- comparing ECU flash memory pages to image file --
[17:39:59.968] seg start len ecu CRC32 img CRC32 same?
[17:39:59.984] FB01 00000000 00002000 0DD1921C 40A17AA6 NO
[17:39:59.984] FB02 00002000 00001000 2F74E0AC 2F74E0AC YES
[17:40:00.000] FB03 00003000 00001000 983E77B4 983E77B4 YES
[17:40:00.031] FB04 00004000 00004000 E1FD7D70 E1FD7D70 YES
[17:40:00.093] FB05 00008000 00008000 D3FDA284 D3FDA284 YES
[17:40:00.203] FB06 00010000 00010000 2455974D 2455974D YES
[17:40:00.328] FB07 00020000 00010000 695195F8 695195F8 YES
[17:40:00.437] FB08 00030000 00010000 D755F034 D755F034 YES
[17:40:00.546] FB09 00040000 00010000 32434E89 32434E89 YES
[17:40:00.671] FB10 00050000 00010000 35C372A4 35C372A4 YES
[17:40:00.781] FB11 00060000 00010000 32EDE3D3 32EDE3D3 YES
[17:40:00.906] FB12 00070000 00010000 F3F54840 F3F54840 YES
[17:40:01.015] FB13 00080000 00010000 43CF4BCE 43CF4BCE YES
[17:40:01.125] FB14 00090000 00010000 52D6CF7F 52D6CF7F YES
[17:40:01.250] FB15 000A0000 00010000 D07A764D D07A764D YES
[17:40:01.359] FB16 000B0000 00010000 1B4380E2 7979515E NO
[17:40:01.484] FB17 000C0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.593] FB18 000D0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.718] FB19 000E0000 00010000 DEAB7E4E DEAB7E4E YES
[17:40:01.828] FB20 000F0000 00010000 38439CF7 38439CF7 YES
[17:40:01.828] the image you are trying to flash contains changes to protected areas! exiting.
[17:40:01.828] interface close
[17:40:01.843] interface close
Did I something wrong?
[17:39:59.312] .
[17:39:59.328] .
[17:39:59.343] .
[17:39:59.359] .
[17:39:59.359] .
[17:39:59.375] .
[17:39:59.390] .
[17:39:59.406] .
[17:39:59.406] .
[17:39:59.421] .
[17:39:59.437] .
[17:39:59.453] .
[17:39:59.453] .
[17:39:59.468] .
[17:39:59.484] .
[17:39:59.500] .
[17:39:59.515] .
[17:39:59.515] .
[17:39:59.531] .
[17:39:59.546] .
[17:39:59.546] .
You tried to kill what???? The ROM you tried to flash has been edited in locations that are protected and ECUFlash isn't letting you write to the ECU. Colby programed ECUFlash so people don't brick their ECUs by messing with areas that you shouldn't. What were you trying to do??
meaning disable immo.
One of my friend imported a USDM Evo X 5speed, but lost his original key (except 1 key no immo).
That is why I tried to disable the immobilizer.
He could not start the engine at all.
I had evo9 but not anymore.
At this moment, I drive MK5 GTi for a while.
I'll find a new car , Enfini RX-7.
I'll give her a Haltech E11V2.
Am I Still fishy? -.-
Actually if the ETACS & ECU doesn't match, it wont start. So if I take my ECU and put it into your car, it wont start. When the dealer installs a new ECU, they will hook it up to the vehicle & MUTIII. They have to enter the VIN/Serial Number into the new ECU. I've actually seen this first hand and they called it "coding the ECU" in Mitsubishi terms
BlackHawk_Tsi
Apr 20, 2015 04:25 PM
