evo x ecu questions
evo x ecu questions
i have a turbo gts but i need a tune i am going to try and use the evo x fuels maps to get correct fueling for my engine. my question is without the timing maps would the fuel maps work for a turbo motor? the evo has much more agressive fuel map so i figured that would work for my application since i'm using a complete evo x turbo setup. what do you guys think. basically i copied the fuel maps onto my definition file for my stock lancer gts and left the timing maps stock.
I would use the Evo timing maps and mivec maps assuming the lancer has mivec as well.
The lancer will have higher timing which could pose a problem, you will want lower timing initially and as you get more comfortable with your tune, you can increase timing.
I would also start on low boost, maybe the stock actuator level (7psi?) and tune this bad boy SLOWLY!
Again, I cannot stress enough to start slowly and move up over time. Or, he best thing to do if you can afford it is to take it to get tuned professionally by a well known EVO tuning shop...IVEY/GST/RRE/AMS....
EvoM Community Team
I would not base anything off the stock maps for another car. I'm assuming the intake manifold, intercooler, head, exhaust manifold, flow level of the exhaust, and all the way down to the MAF are all different. If the stock evo maps are aggressive, you're already off to a really bad start.... they run 9.5:1 AFR from the factory and are so rich that they break up!
Based on your questions it sounds like you need a little more information about tuning before you dive in. I might recommend using a professional tuner to get you started and learning as you go.
evo ecu
i do have the evo x injectors installed but im running the stock gts pump for right now. i did try to flash my gts ecu with the evo x and it ran like crap after about 2 mins. the car studdered and wouldnt go over 3k with some serious knock. so i figured that the evo x timing maps may have been a bit high. i was throwing a code po365 which is the mivec exhaust cam sensor. im think i might need to use the lancer gts base mivec maps to avoid knock when looking at the two definitions side by side the evo x has a timing set of 21 intake and 24 exhaust verses the lancer gts of 13 intake 15 stock. i plan on getting a profesional tune asap but need a base tune to get me to the shop doing the work.
I would not base anything off the stock maps for another car. I'm assuming the intake manifold, intercooler, head, exhuast manifold, flow level of the exhaust, and all the way down to the MAF are all different. If the stock evo maps are aggressive, you're already off to a really bad start.... they run 9.5:1 AFR from the factory and are so rich that they break up!
like what tephra said it will either be getting a professional tune (highly recommended)..or if you want to do it by yourself, start from scratch using your maps..also there are a lot of factors that wouldn't stack up with your car (like what fostytou said)..it's a totally different car especially in the inside..compression will be different and all..
what you could do is ask around the lancer area forums that has done turboing their cars..we also don't know how good/bad your shortblock will be..good luck!
EvoM Community Team
If you just need to get it to the shop doing the work and have only changed injectors (NOT MAF) then all should need to change are the injector scaling and latencies. If you stay out of boost and higher RPM, which you should on a totally untuned car, that should get you to the shop flawlessly.
Evo_Goodness
Aug 30, 2016 04:00 AM
