How to flash car after COBB?
Hi
Have some problem with flashing EVO X
Car was flashed by COBB and now car has new owner w/o COBB flasher
Reading log by ecuflash :
[19:27:47.364] Device Firmware Version: 1.07.2597
[19:27:55.695] -- loading kernel --
[19:27:55.695] -- connecting to kernel --
[19:27:55.695] kernel get version
[19:27:56.070] ECU HW part number : 1860A981
[19:27:56.085] ECU SW part number : 1860A98101
[19:27:56.116] VIN : JMBSNCZ4A9U000402
[19:27:56.132] -- unlocking ECU --
[19:27:56.132] starting session...
[19:27:56.397] requesting seed...
[19:27:56.397] interface close
[19:27:56.428] interface close
And then i try wrote stock rom from other car :
[19:28:28.489] 53040007 (142 tables) inheriting evo10base (102 tables)
[19:28:28.489] 1048576 byte image read.
[19:28:29.379] J2534 API Version: 04.04
[19:28:29.379] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[19:28:29.379] Device Firmware Version: 1.07.2597
[19:28:31.674] -- loading kernel --
[19:28:31.674] -- connecting to kernel --
[19:28:31.674] kernel get version
[19:28:32.017] ECU HW part number : 1860A981
[19:28:32.049] ECU SW part number : 1860A98101
[19:28:32.064] VIN : JMBSNCZ4A9U000402
[19:28:32.080] -- unlocking ECU --
[19:28:32.080] starting session...
[19:28:32.361] requesting seed...
[19:28:32.376] interface close
[19:28:32.407] interface close
Can someone help with this problem?
Even the "stock" map from the map selection is a stock REPLICA map, with their locks in place. There is an option to uninstall on the AP, and this will flash the original map (which is saved when you first install) back onto the car. Process takes about 5-10 minutes, very simple.
MonacoGP
10
Jul 17, 2011 08:28 PM
