Should I sell my AP and just use the ECUtek stuff?
i've already gotten an etune with Mellon once using the AP. I'm doing it to try to get some of my money back out of the AP and because I don't use it on a regular basis, I get sent maps that I use and once I get the right one, i'll be all finished and won't need anything except to take the occasional log.
1 Post
Evan, read this all the way to the bottom, links to everything you need to get rid of the AP and go into the light
http://www.mellontuning.com/index.ph...ex&cPath=18_44
If you aren't getting a custom tune, and don't have time to futz around with tuning and just want some instant set it-and-forget it power the AP is great. You can throw a Stage 1 map on your car within 5 minutes of getting the AP knowing nothing about it - its stupid easy.
I had an AP and recently sold it because CBRD wanted to use ECUflash to tune my car - otherwise I would have kept the AP because it was so damn user friendly and easy.
Hey Pinocchio, don't jump to the water
There is a bunch of sharks waiting for you. lol
Buddy, without a bigger turbo you won't add too much with a bigger IC.
At the point that you are, the next step, is a bigger turbo, gas pump, run e85, bigger injectors, etc
I won't lost my time tuning a bigger intercooler
Correct me if I’m wrong but the stock IC can hold 30 and 35 psi peak, for the stock turbo there is no need to change the IC,
The less money option for you right now is to call cob for an e-tune and ask for a "next 4th of July fathers day discount" they will hook you up for sure
Or learn the AP software and data logging / tune it your self
I love to be my own boss and tuner, I don't need to go to some “Diva tuner” asking for $$$ favors.
An IC is a good investment for sure, but I don't think it's necessary until a lot of other things are addressed.
The stock IC does not have a flow issue at stock turbo levels as far as I could tell, so the only real gains would be from possibly a lower pressure drop and maybe heatsoaking.
Edit: and who cares about untuned results, the IC could've swayed the afr a point and that could account for 22whp easy.
EvoM Community Team
Completely agree with you here. As many 4B11s that have popped, there are a very select few tuners in this country I would trust with bolt-on parts that REQUIRE a custom tune. A dyno tune is the only way you're going to get it as well.
