AFR question/problem
I mean, I would like to see you scale the upper end of your MAF down a hair to bring the AFR leaner. That will make the Fuel Map look more like the Actual AFR.
I did it with mine when I ran into this situation. (Well, I changed the above table first, then Scaled the MAF down a hair in the upper voltages)
scheides
Oct 22, 2021 08:59 AM
Raceghost
Feb 11, 2017 10:27 PM
