Deatsch werks 1300cc injectors review / Scale / Latency
#76
They aren't just "hmm they kind of seem louder then others"
They are "wtf is wrong with my car?!"
I can hear them over the dyno and the huge dyno fans
- Bryan
#77
So is this the ticking of the DW's you are referring to, I never knew what people were talking about when they said the 1000's made noise but you can hear a "ticking" in this vid of my car idling.
http://www.youtube.com/watch?v=XdzA2PgRMqE
So basically the 1300's are that x1000!?
#81
Would be nice to see a high-Z injector from FIC that fills the gap between 1100 cc and 2000 cc, but to be honest, I think many people overestimate the injector size needed. With my FIC1100s, I'm at 410 whp DJ on E85 at 75% IDC. Those numbers tell me that 550 DJ whp on E85 is possible with the FIC1100s (as long as the pump can supply fuel). With a slight bump in base fuel pressure, 600+ whp DJ should be possible without passing 100% (ECU) IDCs.
#83
Just a reminder, the uber clackity clack ones have been the "bad" sets with lopey idle, etc. The ones that are "ok" aren't clacity clack and idle normal
- bryan
#85
The DW1000's worked great on every car I tuned them on so I'm not bashing DW at all, but I also am the one to keep the community informed.
I know this is a horrible way to state this, but injector install is so easy on the 10 I would just put them in and see how they work on your car, you might have got a good set.
- Bryan
#86
Well "ok" in that I haven't had a set of 1300's that just dial in perfect yet, however I've only tuned about 5-6 sets so far.
- Bryan
- Bryan
If I had spare money I would probably buy a set of the FIC 1100's then I could run those at higher base pressure since I have an AFPR, but who knows.
#87
I am more worried about having to shell out more money for another set of injectors and miss the remaining non snow days I have.
- Bryan
#88
Life goes on I guess. I like DW, they have served me well.
I just hope mine work because they picked out a set that flowed uber for me, 1400cc's and i don't know if they will be able to find another set.
#89
Let me start by saying I don't know much about tuning. I just want to fix the latency so my rough idle improves until I get properly tuned next month. I entered in the scaling and latency values Hollywood X posted, using Cobb software, but I am unable to enter in the values that exceed 3.825 Could someone please explain how I can correct this? Thank you.
mrfred
23
Jul 3, 2017 06:59 PM
Raceghost
Jun 1, 2016 12:30 AM
