Tactrix Cable and Flashing Questions
I posted some questions on the RA section but that forum s usually dead on the weekend and I know the Evo community has more experience with this kind of tuning.
I got my Tactrix cable in yesterday and after reading some threads over the past few days I figured I would just start by reading my stock ROM and trying to save it before messing with anything else.
1) My cable came with a separate cable with a headphone connector. I saw some older Evo threads mentioning a second plug next to the OBD-II connection but the RA didn't have it. Also I was able to connect to the car using OpenECU without issue so I'm assuming this isn't necessary?
2) When reading the ROM on the ECU the car started displaying error messages on the center display (Car is overheating, service AWD, Service transmission). They all went away once it was done, is this normal?
3) Once my stock ROM was read I received the error that I didn't have the correct definitions. It appears I need an XML file however none of ones I could find seemed to work. Where can I get the correct XML? Will I need this or another XML to load the GST base map?
4) I read on some threads that i should clear DTCs after flashing. I just went out to try and clear the DTC and didnt have much luck. After reading the ecu again, i chose to Exit Programming State then Clear DTCs. When I did I got this message in the log window "Flashing tools do not recognize flash method"
I now have the Service Engine Soon light on but I went for a quick drive around my neighborhood and everything seemed to work fine. Can I just go to AutoZone and have them clear the codes until I can figure this out?
I appreciate the help
1) the second connector is only used for older evos.
2) that's normal.
3)send me a pm with your email and i'll send you all the files you need.
4)depends on which evoscan you have, some work for DTCs some don't. i use pcmscan do read my codes but that's only because i bought the software when evoscan couldn't log knock thinking pcmscan could. turns out i use it for something at least.
yes you can go to autozone and have them clear it out. ask them for the code number so you can get an idea of what was wrong.
hope that helped some. happy 4th
2) that's normal.
I figured as much but wanted to make sure
Cool
Done
Im using ECUFlash version 1.42.2595
Actually I went and they said they cant clear codes So I just left and right after the light went off. From what Ive read on other threads the light is caused by the ECU and SST not communicating during the ECU read process.
Yes it did thanks
Cool
Yes it did thanks
Yes the SST will cause codes. It goes away.
He was talking about EvoScan, not EcuFlash... to read your codes. The newest EvoScan can read and clear my DTC on a 2010 EvoX.
If Cript doesn't have your definitions, I know I do.
What am I doing wrong?
Bewstzalot
Jul 7, 2017 01:35 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 10:47 AM
