Evoscan 2.7.0090 released
Reinstalled 1.43.3000
OS W 7 pro aswell
Guys,
I didn't try the EcuFlash link as my EcuFlash is working fine and I have the same available on the tactrix website.
As far as EvoScan, I have been using the new version, but I could not get it to read/clear DTC's. I recieved a "no response from ecu" message in the side window pane.
Anyone else get this to work?
I can confirm that map tracer works, and so does "logs vs RPM" or whatever it's called.
I'm still using Mode23, is that still prefered? Have the other modes increased sampling speeds yet?
Mode 23 is still preferred.
I'll have to try this new version, as I've never been able to get the vs. RPM to work! That's good news!
As for read/clear, you have to make sure that you've selected the ECU with the code (we have multiple, don't forget). Down in the bottom right, try a couple different ones if you have a code.
I re-installed the beta after deleting the registry entries. Now connects fine. Able to open and upload all ROMs exept for
Drum roll.....
TEPHRAMOD V1
Soon as I try to open the ROM the program locks up.
Drum roll.....
TEPHRAMOD V1
Anyone have any input on this? I've gone over the xml files so that's not the problem.
Same problem here.
Guys,
evoscan
Aug 16, 2020 04:22 AM
FS[MidWest]: Evo 8/9 Partout!!! Something for everyone!
evotuner04
For Sale - Part Outs
37
Apr 21, 2016 03:04 PM
evotuner04
20
Mar 10, 2016 10:31 PM
evo4mad
Mar 30, 2007 09:03 AM
