EVO X ECU connection.
Hey guys,
I need to know if i connect the ECU connector PIN 4 (ignition coil 1) that i can get a tacho (RPM) reading for my hks turbo timer type -1 !!!!
Please help.
thanx
Please help.
thanx
There is no way to do this without a device between the source (any) and the tach to convert the signal from the CAN signals.
So, let me repeat there is NO WAY TO DO THIS without a converter for the signal wire, IIRC Autometer produces something like this.
http://www.autometer.com/tech_faq_an...x?sid=3&qid=13
http://www.autometer.com/cat_accesso...il.aspx?vid=99
aem, connection, connector, connectors, ecm, ecu, engine, evo, hks, hks turbo timer, placement, type, type -1
