Anyone try this --> Bt OBDII Android scanner/monitor
#31
http://www.centralcomputers.com/comm...oduct_id=72962
I really don't want to do the rear O2 logging with ECU.
#32
You think something like this would work?
Hopefully they will consider it now that the community, or at least you and I, have spoken
#33
Well I think that thing would have to be plugged into a serial-usb adapter since that is what most o2 sensors output right? Working under the assumption that we are able to convert serial to USB, I can't see why, in theory, we should have a problem with a follow-on USB-Bluetooth connection. But theory is one thing and we already know there are serial to USB adapters that don't work [shrug] It would be up to Hamish et al to actually implement it.
#34
Mount it under the seat or in the glove box and you're good to go. At least I think that should work right? Not sure how the x-wifi does its thing.
Or root your phone and so you can enable adhocs http://forum.xda-developers.com/showthread.php?t=754961
#37
This one:
http://cgi.ebay.com/ebaymotors/WIREL...#ht_4134wt_798
Or just do an ebay search for BLUETOOTH OBD2
#38
Sounds like you need to get your hands on a nice cheap small wifi AP, like this (http://www.amazon.com/D-Link-DWL-G73.../dp/B0002Z45DQ). Power required is 5v/1.2 amps. There are plenty of 12v adaptors floating around that fit that. Heck I have a few in my spare parts box ;-)
#39
Yeah the more I read the more it looked like adhoc fixes were hit or miss. Though I didn't dig too deep into alternate ROMs that might solve the problem. I'm on Virtuous myself. As it is I'm getting ready to start experimenting with other ROMs for their Bluetooth Stacks because I really want A2DP to work with my new radio and from what I've heard the stock HTC INC stack isn't very good. So far though, with the Virtuous BT Stack I have had decent connectivity with the OBD2 BT dongle (cheapie from ebay). Maybe I'll get lucky and the Virtuous BT stack will work well with my new Pioneer [shrug].
#41
Silver Sponsor
Hmm, I'm getting perfect connectivity with my new Evoscan4Android software using my BTStack on numerous Android devices to many bluetooth adapters. It auto prompts for pairing, and it auto prompts for the pin #. I'm just building the gauge display system, so that the gauge templates can be reused across the different evoscan platforms. None of my android devices are rooted, you can use bluetooth out of the box with android, which is sweet.. not like iPad, has to be jailbreaked to run Bluetooth. I hate ipad still I need a way to take screenshots on android... any ideas?
#43
acidtonic hit the nail on the head. Emulators are how most devs take screen shots.
So just to be clear, before I get too happy in my pants, you are telling us that you now have evoscan running on an android and connecting easily to various OBD2-BT adaptors?
Now for the key bit: What about Mode23?
Because while I have no doubt evoscan4droid will be sweet and probably better than Torque, the fact is I have torque and it works, but it does not log everything we need and as best I can tell seems to have a boost ceiling of 22-ish psi
#44
#45
Silver Sponsor
emulators can't connect via bluetooth though?
I am going to connect to the live android via the SDK, and get some screenshots for you guys that way.
JumperAlex, you have already mode23 on your evoscan gpsnav perm installed plugging in your phone everytime you get in and out of the car.. I really don't see it happening
