What RPM do you idle at?
Just wondering where all of you are when the engine settles down... mine goes down to about 800, bounces from that to 1000 for about 5 seconds... stops and then does it again... no idea on that.. how about you all?
well I know adding an intake on the X will lean your car out, so if your tuned and u threw an intake on there when u werent tuned for it, it can throw ur tune into a funk. Did you have idle probs when u were tuned? I doubt it.. i would talk to ur tuner about a retune and tell him bout ur idle issue. u need to get that green relay ASAP
Idle dead solid at 750-775 (logged values) on 1100cc injectors
even with my open element filter (AMSOil) I notice little/no idle fluctuation with AC on. heat should not mess with MAF readings...
