Question: Cams or Turbo
I have an option to do either cams or a turbo. What would benefit me more in the power gains? Turbo would be a Dom2.0 , cams would be BC most likely.
Current Mods
AGP piping
AGP IC
Injen Intake
3 port
non 02 turbo back single exit
mods to be added when the turbo/cams go in:
255 fp
injectors
02 dp with tial ewg
Thanks :]
Current Mods
AGP piping
AGP IC
Injen Intake
3 port
255 fp
injectors
02 dp with tial ewg
Thanks :]
What fuel / boost level?
If you are already choking out the stock turbo cams won't help too much. The turbo will most likely get you more power, but you will loose a little area under the curve.
The cams work pretty well on the X, but you may still get a lopey-er idle and some changes at part throttle that might be less desirable.
^Well you can do that stupid ATP downpipe with an external gate but its totally unnecessary. The EWG will screw your spool and it will be really expensive. Just buy the blouch 20psi actuator and be done with it for a wastegate. If you want an EWG go t3 kit.
How bad does the Dom surge? Ive been contemplating cams for the last year, reading and re-reading about gains and pros/cons. The turbo just seemed like a more ideal way to get safer power while boosting the same pressure.
The ewg option was just to be able to hold boost better and not have turbulence in the exhaust piping = less restriction
Ben@AGP
112
Feb 18, 2011 08:11 PM
