noob question, how i can get up the boost?
I tuned today my friend's evoX but i can not get more than 17psi with 22psi spike and 15psi on red line.
I put the boost target to 160, (maximum) the boost control load offset to 150 (80 stock),
I get up the values on the reactive solenoid max total upward correction and the reactive solenoid base wgdc to the max.
The car has a perrin turbo back.
EvoM Community Team
It sounds like you are trying to blow the car up. 310 load is quite a bit for a car with just an exhaust... and if you upped the correction it should do it's best to make it there.
It sounds like you adjusted most of the necessary tables (boost target, load offset, reactive solenoid base).
Please stop and read the how to tune an evo sticky or Merlin's guide:
https://www.evolutionm.net/forums/8984700-post59.html
https://www.evolutionm.net/forums/ec...-tune-evo.html
AFTER you UNDERSTAND exactly what you need to adjust, you may need to increase the passive wgdc also, considering the BWGDC maps were probably at 100% already and you simply increased them to a value beyond full-on.
Friends don't blow up friend's cars... make sure you know what you are doing!
fostytou
i have never got 310 load, as i say the load is only 240 splike with 220 at mid and 200 at rev limit. I put the measures at PSI for a easy reading
The car has the boost limit at 260, but i never get the boost cut
I have read the Merlin's guide many times and how tune an evo and this is the reason of my question, because i have rise the values including the passive wgdc and the boost is a little more than stock
I have tuned many cars in 8 years and noone have blow the engine, including NSX supercharger, or elise with turbo kits
Or just remove the boost line leading to the WGA, you'll get max boost, for one pull.
You really want to test incremental change and make sure you read the tuning guides out there about how to adjust the boost via ECUFlash. Sometimes a good old MBC works out better from a simplicity standpoint.
thanks
I will re-start all the process again, my boost target is only 1.4 bar (21 psi) or 240 charge.
I tuned the fuel and timing with great and fast results, and i only need tune the boost right now to have a consistent boost over all the revolution range
I use PID algoritms for boost control over some EMS like hydra, and the evo ecu has a lot of variables to control boost, this is the first time i try to control boost via OEM solenoid. All evos i tuned had a Electronic boost control like the apexi avcr or HKS evc6...really good boost controller
fostytou
well, today finally i got the boost i want it.
I needed to put the reactive solenoid tables to 100%, boost target to 150 and the load offset to 100.
Then i played with the passive solenoid tables with values arround 70...this was the error, because the stock value is only 10, and i only get small incrementals for it.
Now, the car has a 1.5 bar (22psi) spike, with about 1.4/1.35 bar in the mid range, and 1.3 on the red line
TheIndianGuy
Apr 11, 2017 09:44 PM
LaXGSR
Jun 8, 2009 12:50 PM
