weird ****wittery with AFR and idle
Hi Guys,
I am having a real problem with a tune for a rebuild I am working on.
Basically when doing a cold start the idle will be all jumpy.
The AFR will be crazy lean...
Other symptoms like high load, high MAF, high boost (well low vacuum) all exist, but I assume this is because of the jumpy idle.
These are ID2000's - with my MinimumIPW patch and running openloop idle.
Now here is the kicker, the AFR/idle will be perfect if you give the throttle a kick whilst its idling...
As you can see the IPW remains roughly the same, or locked at the minimum, however on either side of the TPS kick the idle/afr goes from bad to good...
NOTHING else has changed...
So what the HELL is going on?
Why does the SAME IPW result in total LEAN vs 13:1 AFR???
Its almost like the timing is wrong and missing spark or something??
If it was a hardware issue, why does the throttle kick fix it?
HELP!!!
HELP!!!
ID2000
AMS2.2
stock head.
kelford B's for cams (i think)
big **** off turbo
3.5" MAF
4" intake
usual other stuff
I should say he is also throwing a P0300.
which is why I think its timing related...
I should say, this particular motor has been rebuilt recently. The ROM was working fine before hand.
The rebuild (*AFAIK*) consisted of replacing the head (the old head was fubar'd after a valve let go and smashed into a piston)
AMS2.2
stock head.
big **** off turbo
3.5" MAF
4" intake
usual other stuff
I would be curious to see what throttle position is Tephra. Did you log it by chance?
I have tuned that exact setup on multiple different cars and I haven't really seen that.
Mitch
Mitch
Hey Mitch,
Well like I said - before the motor let go this ROM was fine. Well the idle was fine... rich AFR, but thats the limit of the injectors more than anything...
All thats changed is the head... I am not sure if he redid the bottom end (ie new pistons), I presume he did, since they were damaged in the explosion
With TPS and RPM axis rescaled to see it all:
But like I said, why does the same IPW go from producing 18:1AFR (or even higher since 18 is max for the WB) to 13:1AFR???
You dont happen to have a spare set of 2000's to put in to test do you? ( I understand probably not)
I would be curious to see what the fuel flow is out of the injector compared to what you are measuring for IPW. I have seen with the 2000's on a Motec or the stock ECU that once you start to try and go past 1.1ms the idle becomes very unstable as the injector is just no longer able to fuel correctly. (And yes I have seen the charts on ID's site)
It may be a timing issue, but it would be a strange issue unless there is some sort of start up trim that maybe has not been seen yet? I do see the timing advance before you blip the throttle is a lot more unstable.
Strange problem for sure.
Mitch
Mitch
No other ID2000's to try..
Well with the previous build we had a good idle with the MinimumIPW of 1.128ms.
Currently we are using 1.156ms. So if anything it should be better...
But yes anything under(or closer to 1.1ms) means the injectors don't fire properly/reliably..
I am getting him to check the injectors with a stethoscope - but maybe I will get him to pull them entirely...
Lean AFR means that it is missing.
Did you check the plugs / gaps?
Also, the Timing is going to 60 in your graph. That could easily cause a miss.
(Unless I'm reading the chart wrong.)
I have done a lot of the 2000's on both the stock ecu and on Motec's and I haven't seen this issue. It is really strange issue and the more I look at the choppy timing the more I think Golden may be onto something with the plugs.
I am going to tune a Motec Evo X with 2000's right now. If you want any data let me know. ( I doubt it will help though lol)
Good luck Tephra.
Mitch
Good luck Tephra.
Mitch
I say it is hardware related... not a tuning issue.
I would inspect the plugs (known to fail on the X)
I would also check the Ohm resistance of the injectors see they are all the same (they should be). Also you can check the Ohm resistance of the plugs.
Also, if you have stock injectors try to put them in to confirm if it's injectors or plugs.
