Gas saving map?
Old Apr 14, 2011, 10:50 PM
love67's Avatar
Gas saving map?
Hi,
I was wondering how much will my MPG improve if i ask my tuner to tune a "gas saving map" for street use? will this "map" do better than stock map or is this even doable?
Old Apr 15, 2011, 12:26 AM
xhomm02's Avatar
Originally Posted by love67
Hi,
Well, it is possible via timing/MIVEC/WGDC changes, but do not expect miracles, 5-10% saving is possible.
Old Apr 15, 2011, 12:13 PM
Wrex1977's Avatar
You'd probably be better off to drive slower and shift earlier.
Old Apr 15, 2011, 12:17 PM
tipoytm's Avatar
There's a cruise mod by Hiboost that I've used for over a year now. Just search for the thread. I probably saved 2-3 mpg on highway cruising.
Old Apr 15, 2011, 02:09 PM
love67's Avatar
im driving slow and shift so early already...but because my tune the MPG went soo low...
just wondering what is the MPG r u guy able to get? i only have 16-17 MPG with freeway....
Old Apr 15, 2011, 03:13 PM
Robevo RS's Avatar
Hi,
there is such a thing as a gas saving map or transit map in rally, but you need a proper ecu for that , so you can switch between maps. Actually there is 3 different map rally guys using. Race - test - transit/gas savings
Probably you will able to do that with Cobb., not as simple as the rally cars but still.
Old Apr 15, 2011, 05:00 PM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
You can switch maps with the stock OEM ECU while the car is running, so owners already have a "proper" Ecu.
Old Apr 15, 2011, 05:28 PM
droppinbottom's Avatar
Then something is terribly wrong. Are you running in open loop all the time?
Old Apr 15, 2011, 05:34 PM
JEP
JEP's Avatar
16 to 18 is all I get also...
Old Apr 15, 2011, 05:42 PM
I get that around town but definitly better on the highway. And my data is from hand figuring it not by the dash display.
Old Apr 15, 2011, 07:51 PM
Robevo RS's Avatar
Why nobody tunes two maps for the evo then, like one for race and one for DD?
I think that would be something people would pay extra money. For many reasons, besides the gas savings.
I am around Evo tuners and so, at least in the states 8 years now, and i never heard of this on OEM ECU. But at least i know now, this is possible too
It is an awesome thing to have two maps, does anyone have that type a tune currently?
How do you switch maps, with a button like the other ECU's do, the cruise control switch or similar?
thanks for the info .
Old Apr 15, 2011, 08:12 PM
love67's Avatar
^^ Evo X has that...
"EVO X Dyno Tuning for Dual Maps.
Your stock GSR ECU can be programmed to store two maps that you can switch between at will. This feature can also be used as a fail safe for water/methanol injection systems. The maps are switched using the cruise control switch. The cruise control still continues to work normally." copied from road race Engineering...
I already e-mailed my tuner(from road race engineering), now just waiting for his reply and see how much better could it work...because now the gas price is really killing me...im about 3-4 days per tank...
Old Apr 15, 2011, 09:24 PM
dj_rock101's Avatar
I easily get around 18-19 in the city and 24-25 on the freeway. The key is not only to shift early, but let the car decelerate on its own without mashing the brake pedal a lot. Just get a normal tune and you'll see a bump in the fuel economy since stock X runs super rich.
Old Apr 15, 2011, 09:36 PM
disturbedfan121's Avatar
just need the tuner to lean afr's out a bit while not in boost and when the car enters boost it would richen up. i had a map on my miata that made 250whp and still netted me 30+mpg my best rating was 36mpg, but it was rwd and only 2300lbs so its not an apples:apples comparison, but still it can be done, maybe not 30mpg, but upper 20's sure.
Old Apr 15, 2011, 10:01 PM
BakaUnchi's Avatar
I have 29 mpg evo X maps ;-p
Quick Reply: Gas saving map?
