MAF scaling units
MAF scaling units
I'm tweaking a little the MAF scaling on a 53040010.
I have recognized the MAF curve in the bin, and logged MAF volts and flow in g/s at idle, and compared bin with log.
In evoscan MAF g/s conversion formula is x*2/100, but in ecuflash I'm using Airflow16 formula that is x*600/65536. As obvious evoscan reading and ecuflash map doesn't match.
The question is, which of the two is the correct conversion formula for MAF scaling?
dontek
Jun 25, 2010 12:39 PM
