SST Modes, Clutch Pressure and Clutch Slip
#31
Looks like you just need to find certain tables and adjust them higher. Unless they are defined in the TCU or the TCU limits the clutch pressure on the RA.
#34
Is clutch slip really bad for the clutches in this application? Seems like the time is so short that it shouldn't cause any wear (we're talking a couple miliseconds), and at least there is no clutch wear replacement interval from Getrag/Mitsu.
I would think the extremely high pressure of S-Sport mode might be worse overall in terms of wear and tear. The shifts do feel harsher in S-Sport mode in my experience.
#35
naa i would say that normal would induce more wear...
for example.. my old car inside the clutch master cyclinder there was this tiny spring and plate with a tiny hole in it.. to allow the fluid to go through the hole more slowly.. by this happening the clutch would engage slower and would case slippage untill the clutch clamps down all the way 100%
by taking this little plate out the clutch would clamp down right away but would cause a harsher feeling ride. after doing this mod i had no issues... Now with the S-sport modes i feel that this does the same thing.. faster harder clamping = little to no slippage.. which in turn = less wear... but harsher feeling shifts..
with the normal mode shifting it feels and sounds like somone is riding their clutch between shifts.. this is why i dont use this mode ever unless i'm not planning on doing any aggressive driving. if i have to i'll throw it in sport manual and giver.. but i drive 90% of the time in s-sport manual if you shift while not in boost there's no lurching harsh feeling shifts.
pretend your a bicycle.. your not going to try and shift in to the right gear as your climbing ... you shift before the climb and rev it out
#38
Evolution X ECU P/N's
production date- trans- P/N
2007.11.1 thru 2008.07.3- 5 spd- 1860A979
2008.08.1 thru 2009.05.3- 5 spd- 1860B180
2009.06.1 thru 2010.08.3- 5spd- 1860B306
2010.09.1 thru 2011.09.3- 5spd- 1860B474
2011.10.1 thru - 5spd- 1860B788
2007.11.1 thru 2008.07.3- 6spd- 1860A980
2008.08.1 thru 2009.05.3- 6spd- 1860B181
2009.06.1 thru 2010.08.3- 6spd- 1860B307
2010.09.1 thru 2011.09.3- 6spd- 1860B475
2011.10.1 thru - 6spd- 1860B789
Ralliart ECU P/N's
production date- P/N
2008.06.1 thru 2009.05.3- 1860B106
2009.06.1 thru 2010.06.3- 1860B308
2010.07.1 thru 2011.09.3- 1860B485
2011.10.1 thru - 1860B790
VIN Code and Variant needs to be programed each time ECU is replaced.
I remember an email a few months back in regards the the TCU for the Ralliart/MR, I will look and see if I can find it.
Ralliart ECU P/N's
#40
would changing clamp load values in Normal mode to the values of S-Sport clamp load hurt the transmission over time?
It would basically shift as it does in normal mode, but use the clamp load of S-Sport mode.
what do you think, Bryan?
crak
906
Aug 14, 2022 02:41 PM
TheHolyLancer
Mitsubishi TC-SST Discussion
17
Mar 17, 2016 02:41 PM
tscompusa
Sep 14, 2012 12:15 PM
