EvoSCAN BOOST guide
EvoSCAN BOOST guide
I am looking for a easy way to measure boost using evoscan/gauges if possible in PSI..not kpa/bar etc...can anyone please shed some advice-car is stock pretty much.
Thanks
Thanks
Evoscan + tactrix + laptop = boost logging. Log in psi, bar or whatever you set it up to. Evoscan has virtual dials you can set up ig you want. Or standalone android evoscan logger, or simple boost gauge running from a vac line.
Bear in mind that if you haven't tuned your boost then your cars psi will be reasonably standard
What do you mean its not logging properly? Are you running a stock ROM? Mode23? EvoScan is pretty simple to setup those gauges.
How about a pic of your settings?
i think I had it setup incorrectly....I realize it is easy to use but I think it as in kpa/now changed to psig....metric-->imperial.....thanks guys..going to test now should be fine...hopefully helps out someone else....
LOVEMYX
Jun 13, 2017 06:06 PM
evodziobak
Oct 25, 2011 05:17 AM
