Evo X MAP Sensor
it's a 3 bar map sensor. 3 bar = ~43.5 psi.
typically most pressure gauges are most incorrect at their extremes and most accurate in their mid range so you would want to upgrade sensors if you were thinking about testing that number out.
you can make more boost than the sensor reports but clearly that's going to inhibit load calculations and logging.
omni 4 bar map sensor if you intend on running > 29 psi
WTB[SouthEast]: Evo 8 Cam sensor with housing
Igaly1021
Jan 17, 2017 07:29 PM
[WTB] WTB IAC Sensor
NewEvolutionIX
Sep 5, 2016 06:35 PM
