Open Source vs Cobb
Open Source vs Cobb
I am purchasing a car that has been tuned on Open Source. Being as I am more familiar with Cobb which is what my GTR is setup on, is there any advantage/disadvantage to Open Source?
i.e. - How can I view parameters with the open source programming?
How to change maps on the fly? (On my GTR you just use the cruise control buttons to change maps - Is it similar on the Evo?)
Cobb is also coming out with their V3 of the Accessport which looks wayyy better than my current V2. So I may just hold out for that anyway...
Thanks!
Thanks!
depends on if whoever tuned the car. Evo's who run the tephramod have that dual map capability like your gtr. The only way to view param's is to get a tactrix cable I BELIEVE. If it wasn't setup during tuning for dual maps it will not posses that capability. I'm open sourced tuned, I only have a single map. The way it was tuned is pretty much all I have. I chose it over cobb because its cheaper than buying the pnp box then paying for a custom tune. That and you dont have to have the lil ap sitting somewhere.
Thanks...It apparently does have two maps...Pump and Race gas...I think he said it's some combination of pressing the AWD button or something...
I will probably switch it over to Cobb at some point since I seem to be more comfortable with it.
choice's
I have both. I like the A/P and still learning EVOSCAN which I will use it exclusively when more secure with using it. It is the bomb, make sure you save those maps when converting back to cobb. If I had known what I have now it would be 1st a pro tune and EVOSCAN after. There is so much more.
jakgal04
43
Jun 19, 2016 04:52 AM
FS[Mid-Atlantic]: Cobb ap v3 350$
MisterRegato
Nov 9, 2015 01:26 PM
