what does it mean when the car is idling and the afr shows ---?
so recently, (as the climate got colder) i noticed my afr reading has been a little different. car seems to be running fine.
for starters, the reading is a lot slower. another member pointed out that if i have a leak in the exhaust system, (ie dp) it can cause a slower reading. before, the aem afr gauge would change numbers several times/sec. now it reads a lot slower (numbers change gradually).
coasting at 40mph in 4th gear, the afr will show anywhere from 14.5-15.5 (normal). once i let off the throttle, afr goes to ---. but then when i come to a stop, the afr will change from --- to 11-12.5 (aka rev hang). the car is still idling below 1k rpm like normal. it takes a good minute for it to go back to stoich.
now, it's just getting worse. last night on my way home, as i was coming to a stop, i looked at my afr and it showed ---. i was expecting it to shoot up to 11-12.5 again as usual. but this time it just stayed at ---. and yes, i was sitting at a light idling and the afr is showing ---.
at this point, i'm guessing/hoping that nothing is wrong with my car, but instead my aem gauge reading is off. i'm going to try and go see my tuner soon but if anybody has experienced something similar, please let me know.
Mine started doing that the other day. I approached a stop light and put it in nuetral and it would show --- for a good 5-7 seconds before eventually climbing back to the normal idle reading.
Im not sure if the sensor is starting to go bad also, but I have to send AEM my oil pressure sensor that lasted a whole 30-45 days before taking a poop on me. And if my wideband sensor is starting to go, then it means it lasted a whole 6 months.
Sometimes there isn't enough exhaust flow on idle to get a proper reading. It's more normal if the sensor is further downstream. Sensors do tend to show lean when they're on the decline, too. As far as going -- on decel, that's perfectly normal. There shouldn't be any fueling on decel, so it'll show lean. Regardless, it's just a common sensor issue. No worries.
Slo_crx1
Aug 25, 2015 07:06 PM
ezzey
Jul 19, 2012 07:41 PM
nj1266
125
Jan 12, 2010 07:37 AM
