Garrett's 714 AWHP / 538 AWTQ Evo X - Mustang Dyno - Boostin Performance
Garrett came to us in July with an Evo X for a tune and a few other modifications. After getting used to that car, Garrett decided it was time for a little more and purchased his second Evo X. This second Evo X of his made 681 AWHP & 487 AWTQ on our Mustang Dyno on E85. Due to the restrictions of the stock Evo X ignition, we weren't able to push the car to it's full potential on this fuel. But this time around, and with the help of Spark Tech Ignitions newly released -"Spark Tech EVO X Sequential CDI Ignition System," we have some exciting new results.
MODS:
- Boostin Performance Stage 3 Ported Cylinder Head
- Boostin Performance custom 3.5" Test Pipe
- Extreme Turbo Systems 4" FMIC w/ Full Piping
- Built Bottom End
- ETS V-band Turbo Kit w/ Precision Turbo & Engine 6466 Turbocharger @ 40psi
- Injector Dynamics 2000cc Injectors
- Spark Tech Sequential CDI Ignition System
- Stock ECU RE-flash Dual Map Tune (E85 & 93 Octane)
Only change/addition to the car: Spark Tech Ignitions EVO X CDI Sytem - Plug and Play
MODS:
- Built Bottom End
Its a 2.0L. The car was OK with the factory ignition up to 35 psi, even then gapping down the plugs did not help. Ill try and grab a dyno sheet before we installed the ignition, im not sure what power level was.
Boostin Perform
Jan 31, 2015 07:00 PM
Boostin Perform
Evo X Dyno Results
Jan 9, 2015 10:50 PM
Boostin Perform
Evo X Dyno Results
Oct 6, 2014 06:14 AM
Boostin Perform
Sep 20, 2014 06:54 AM
05-EVO-GSR
Evo X Dyno Results
32
Jul 31, 2014 09:40 PM
