HKS F-Con Pro
HKS F-Con Pro
Hi All,
I had an HKS f-con pro fitted to my EVO-X but when it's connected all traction control / stability control etc: does not work. the car runs well, but can not seem to get to the bottom of the problem.
Is this anything anyone has come across? I had to leave shortly after the problem so have not had a chance to really look into anything but if anyone has any experience / ideas of where to start when I get home it would be much appreciated.
Raymond
Raymond
Hi All,
Raymond
Raymond
Are you running it stand-alone? Or piggy-backed on the stock ECU?
If you're running it stand-alone, you won't retain any of the OEM traction / stability strategies. If it's piggy-backed, as long as those channels are connected via. the jumper harness, everything should work.
Do you have Power Writer software? USB dongle?
KaRboN
Northeast Region
Jul 12, 2010 06:52 PM
KaRboN
Jul 5, 2010 09:01 AM
evodave
21
Jul 13, 2008 08:09 AM
