X Maint. Schedule & Fluid Specifications
Old Oct 1, 2009, 05:02 PM
  #31
kijima's Avatar
Oceania - Ralliart Lancer
TC-SST fluid 105,000 km or 84 months. Severe conditions 45,000 km.
TC-SST fluid filter 105,000 km or 84 months. Severe conditions 45,000 km.
Old Apr 4, 2010, 02:00 AM
  #32
MYEVOXGSR's Avatar
no, actually they dont even do 75% of all that, to actually check the car like that schedule for them is not wort it, 1st if you have an evo and you take it to the dealer,,, make sure that they are going to give it to the Master tech, becuase the mayority of time if it is a small part or a dealer service they always give it to the newves... trust me i know...that 1st because i was a mechanic in an (XY dealer) and everitime they will give performance cars for a service or a small part to newves)
Old May 1, 2010, 12:35 PM
  #33
brtecson's Avatar
Wow, this is a very informative thread, thanks for putting it together.
Old May 5, 2010, 12:59 AM
  #34
ganghyung's Avatar
pics are dead..
Old May 27, 2010, 11:16 PM
  #35
NWM_Tech's Avatar
Disagree With Mitsu
Disagree with Mitsu on the interval on the transfer case. It should be a 15 K change.
I've seen a few of these burn up already. When you change the fluid at 30 K it's hella dirty. Think it's because it's such a high load area, and it's such a small volume. It also doesn't hurt to overfill it a bit.
Old Jun 25, 2010, 11:19 PM
  #36
toro10's Avatar
Interestingly service group with whom I've communicated says transfer case and trans-axel both should be changed around 15 K which is a 500 ish service ??). Does your opinion above apply to both or just transfer case. My thought was to try to do it around 17K or so miles.
Old Sep 13, 2010, 06:27 AM
  #37
triniwondaboy's Avatar
Fluid quant. disparity
There are huge disparities in the fluids link amounts and the maintenance schedule amounts. Like eg the maintenance sched calls for 8.3gallons of the Dia Queen but the fluid post says capacity is 2.3qts??
Is it that the qts suppose to be gal in the fluids post?
Old Apr 12, 2011, 02:27 PM
  #38
wwEVOsss's Avatar
Pics are dead. Can anyone update?
Old May 30, 2011, 09:30 AM
  #39
trick3d's Avatar
So is the consensus that we should change the fluid and filter at 10k and then at the 30k,60k etc.?
Thanks.
Old Aug 24, 2011, 11:41 AM
  #40
mm1ssdv's Avatar
Oil Weight
So what is the actual oil weight required?
Old Aug 24, 2011, 11:50 AM
  #41
Kracka's Avatar
For the engine? Mitsubishi calls for 5W-30, but many of us in warmer climates use 10W-30.
Old Aug 24, 2011, 06:23 PM
  #42
mm1ssdv's Avatar
thanks kracka!
Old Oct 8, 2011, 10:22 AM
  #43
HATED1's Avatar
good info! thank you!
Old Nov 15, 2011, 11:37 AM
  #44
darkstarbd's Avatar
what about the plugs?
Old Dec 9, 2011, 12:09 AM
  #45
iEvolutionX's Avatar
Evolution X stock plugs: NGK #8
Search Number: ILKR8E6
I = Iridium
L = Long tip
K = 12mm thread width
R = With Resistor
8 = Heat range number
E = 19mm thread length
6 = 0.6mm gap
Quick Reply: X Maint. Schedule & Fluid Specifications
