Is a turbo timer really necessary?
#47
TT = laziness
I have an oil temp guage and the normal operating oil temp I see typically is anywhere from 190 to 210 degrees F. On a really hot day Ill see 220 deg F. I believe the car is in closedloop or warmed up at about 180 because you can feel the car is running much smoother.
I ALWAYS sit and idle my car until the temp goes down to 180-190 deg F. Screw the TT, I always leave early enough to allow for the cool down period. If Im late to work...dont care...Ill still sit and idle. I LOVE MY EVO.
Tip: To accelerate cool down, turn your AC to full AUTO...the temp, fan...everything. This will turn on BOTH radiator cooling fans to HIGH SPEED...you can literally watch the needle on your oil temp guage drop...pretty quickly too! I cool down from 200 to 180 within 3-4 minutes. To cool down even faster...open your hood...youll be amazed how fast itll cool down.
So now...there is no excuse for bearing failure due to oil coking!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
#48
no it doesnt hurt for sure.
Now talking about track events and so:
Not cooling down the entire car properly, can do damages like warping your rotor etc
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
So when you do a proper cool down the TT is not neccesry, ergo doesnt do anything really.
If doenst do anything , then cant really hurt anything, unless you thinking about money you spend for nothing
Normal DD your car will never go that high temperature when you need to worry about your turbo sizing on you. Other then that, you should cool down the entire car properly.
And this is true even for a N/A cars too.
#49
Just A little info the EVO X comes with a oil cooler stock on both the GSR and MR so a TT is not needed for off track or rally use - I.E. driving to work, little high way spints, or even long drives.
Normal driving or even spirited is not enough to create enough heat for cook off add in the fact all X have oil coolers I.E. next to the pass fog light the little IC behind the chicken wire.
It is only needed if you like ghosting your car when you park or to warm it like others do other then that its a waiste of time and money for EVO X owners.
Now other turbo cars like older EVO, STI, Supra, older GTR, ect benefit from a TT Because they have no stock oil cooler unit so there is some what a need for when they drive there cars hard.
But if you don't dog your car out even with out a oil cooler you don't need one thats why they do not come with it.
Side not when all those cook of cases came out for turbo cars the oil they had back then is no where near as good and clean as the oils we have today.
Don't buy some thing you don't really need instead spend that $100 on parts that will really affect your car.
#50
Silver Sponsor
Most everybody has a good point either way. Oil coolers and water cooled turbos help to keep from cooking oil in your turbo, but they don't prevent it. A timer definitely doesn't hurt anything and it comes down to whether you want it or not. Either way, it is a good idea to let the oil cool down before you shut the car off if you're driving hard, whether you wait in the car or use a turbo timer.
-Zach
-Zach
#51
pretty sure the older Evos had oil coolers. I know for a fact the 7 and 8 have oil coolers.
#53
To my knowledge all of the Evolutions 1-10 have an oil coolers on them. The Evolution 4-9 will use basically the same oil cooler and have very similar drive train setups with minor updates and changes as they progressed through the years and models.
Thanks,
Dallin
Thanks,
Dallin
FS[Northeast]: HKS Turbo Timer
Freddy302
Oct 11, 2016 05:55 PM
emperor496
17
May 8, 2012 09:24 PM
cons, evo, evolution, evolutionm, forum, hks, install, pros, purpose, timer, timernecessary, timers, turbo, turbotimer, wiki
