Is a turbo timer really necessary?
I know what purpose a turbo timer serves, but is that purpose really necessary? Is it all that important to cool down the turbo? You would think if it was that beneficial it would come on the car from the factory.
Yes, but also the other side is, if you leave while the car is running, security people might think something is fishy. As I had been asked once by a security personnel why I am leaving my car running. Now, I don't use the TT anymore. Better a stalker than a terrorist.
completely unnecessary if you're using synthetics. A friend who used to work at garrett has performed many tests while there, and he said that synthetics does not gunk up the bearings at all.
Just dont boost hard prior to parking and you can park and shut it right off - no need to let it sit and idle.
Only time you really need let the car idle for a minute is if you boost hard and then park right away.
So no a turbo timer is not necessary - its more of a oh look i have a turbo timer!
If it was required, it would have it stock. Perfect example, the SST clutches will require the car to run for a little while after they are shut off to properly disengage. If the turbo needed a timer, they would have installed one from the factory.
I never got one for my VIII, and I never used an Oil catch can. Never had any issues, car always ran fine without those so called "required" components.
Quoted from Wikipedia:
A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oil from the engine is able to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed. With regard to modern automotive turbochargers, the need for a turbo timer can be eliminated by simply ensuring the car does not produce any 'boost' (during driving) for several minutes prior to the ignition being shut off
