Should my turbo feel like this?
#32
I'm having the same issue! I noticed it a while ago, but it was sporadic, only happening once in a while. It used to be barely noticeable. Driving home from work today, I noticed the car sputtering Dramatically when revved to 5K and past. It feels like the engine is cutting in and out, and bucking. It's horrible. I honestly don't think I can even drive the car like this till the issues fixed. I called the dealership and they said bring it in on a dry day so they can test it. I have an appointment for Thursday morning. I have a long commute everyday (roughly 40 miles one way) and I can't deal with this issue till Thursday. I have a feeling the issue wont be resolved when I bring it there either. I'm actually very pissed off about this. Phewww, sorry to vent guys, I'm just frustrated.
Took the words out of my mouth! I have heard everyone talking about this but never had it happen to me yet because I have not gotten on the car all the way. Well tonight I finally put the gas to the floor and it is sputters bad up top. After 5k the car jerked and ran like crap. I could not beleive that Mitsu would release a car like this! What did they do, let a kid fresh out of school tune this thing???? This is very embarassing for Mitsu.
#33
The works filter solves this problem completely. All of the Xs buck and hesitate past 5.5k, this is normal. It's just overly rich and is easily corrected.You know what's funny, though? Do you guys remember reading the first motor trend pre-production review in which they mentioned this exact thing hurting the 0-60 times, and that mitsu said that they were aware of the problem and would have it fixed by production. Well, I guess they decided to say **** it, we'll fix it later. Hence, this "supposed" reflash that's coming out "soon." Oh well, BMWs have as many or more problems than the evo seems to have, so I guess it just goes to show that no car is perfect. Every time I take the car in a corner it makes me smile. Every times I look at it in my garage it makes me smile. So I had to buy a works drop in filter to lean the car out enough to run correctly, worse things have happened. They will probably never come out with this "reflash," nor will they ever cover anything under warranty because they don't want to spend money if they don't have to. This matters not to me, because the car is pretty mechanically sound, and aside from the ecu tuning and the notchy tranny, there really isn't anything wrong with the car. Plus, I have a vehicle warranty program in my insurance plan that will cover anything from the stereo to the tranny for 7 years/ 100,000 miles! Ah, now that's peace of mind.
#35
Good read. Drove one at the dealer today, noticed the problem right away. Went and drove the owner of the dealership's car and his did it too. I wanted to make sure there wasnt a problem with just the one car.
We will have the ecu fix for this in upcoming weeks. Stay tuned.
#36
The Factory "tune"
#38
I think the cone filter helps just as much. The stutter is still there once in a while and you can still feel the car just completely taper, lose power, and run rich up top. Sorry people but a re-flash from the dealer, a tune, or a piggy back are the only way to really get this COMPLETELY gone
#39
The Factory "Tune" Corrected?
#42
I noticed the same issue with my car and concluded it was the wastegate . We did everything I could using a Greddy EBC and nothing worked . For me the issue came about when I began to run 21lbs . At 18.5 lbs I ran a 13.3 at 104 and at 21lbs I ran a 13.3 @ 105 with the car having the problem . I now run a Forge wastegate I made a custom bracket for and that solved my issue 100% . Hope that helps if thats is indeed the same issue you're having ; as it was stated it does seem to be the very same issue .
We should have some wastegates this coming week
#43
The better question is if they do have the re-flash...do we want it? I mean it could possible lose all that potential all those tunes we keep hearing about give it. What happens when I get the re flash and than order the Vishnu tune which leans it out...boom to motor or what? Will the gains stack with the re-flash? I just have some of these question that plague me.
#45
honestly my car feels slow, and its just not smooth through the rpm's..... and its begining to wear on me. and after i put an exhaust on, the rich mixture is causing my rear bumper to get black sh** all over it...
car is too dam rich! Alot of people are saying the X likes it rich, i disagree completley...no turbo car ive owned likes it too rich... running a bit rich is for saftey leaner A/F make more power, its proven.....you dont want to run too lean and start detonating, but you dont want to run too rich and start missfiring, i believe the x miss fires, the car also pulls alot of timing too.
but im waiting for the perrrin/cobb access port for my X, i dont want to cut any wires...
