Works Short Shifter For 5 Speed.
#33
i don't know if the shifter is any different for the evo, but this is a great upgrade for the gts (and other lancers). after looking more closely at it today, 3rd seems to be dead center and 5th is just slightly to the right, not as far away as it used to be.
#34
Just installed the Works kit 2 days ago. Here's a quick DIY link over on 'X'. I took the pics after it was installed. 3rd and 5th gears are indeed 'closer' together. I went into 3rd a couple of times by mistake (instead of 5th) 'till I got used to it. Tight pattern and more effort to shift for sure. 2nd to 3rd is now much better...more positive
http://www.evoxforums.com/forums/showthread.php?t=4241
#39
I got this installed when I got my flash from works. I also did the shifter bushings and clutch line bushings. All i can say is much better throws with positive shifting. And works short shifter is 30% throw, there is no adjustment on how short you want it to throw
#40
Been using it for about a month. Left and right is definitely shorter. Front and back rowing feels slightly shortened, but not too much. I had to re-learn how to shift from 2nd to 3rd because the short shifter tilts slightly to the left and 4th to 5th because 3rd and 5th is closer together. Like MooseX said in his review, if the shifter rod is any shorter it will be much harder to put it into gears, it is just right the way it is. I also installed shifter cage bushings as well which was much easier. Next up are the shifter linkage bushings .
The Works short shifter will not help with smoother shifting, but helps you get into gear faster by using less effort to get into gear because the gates will feel much closer together.
#42
#43
I had really good luck with the AMS underhood shifter busings and shortening the stock shifter by about a 1/2". My biggest problems with the stock setup was when taking the car to the dragstrip for the first time and trying to aggressively shift... the vague rubber feel of the gears really made it hard to pull off the 2 -> 3 shift. I had to force myself to calm down and pretend I was on a Sunday drive to get it to work. Now it's much cleaner shifting and the height along with the solid feel is making all the difference.
I may consider a Works or other short shifter in the future but for now it's much better than it was stock.
#44
30% give me 40 to 50% i guess i'll have to wait more.
http://www.maddogsts.com/pricing.php
I had these guys shifter on my SRT4 the 58% it was awesome.
#45
That's a pretty severe reduction to pull off without having it effect shifting effort too much. While much of the throw is shorted by a different pivot point, you may be able to cut another 1/2" off the end of the Works shifter but I haven't seen how much thread is on those. Stock had about 1" total...
