Stock wastegate pressure
Does anyone know what pressure the stock wastegate actuator opens at? I'm not asking for the stock boost level. I want to know what pressure the actuator will open at if it had a direct connection with no boost controller being used.
I measured this today, it's roughly 14.0 psi. I'm making another thread in a bit to show pressures after the actuator rod it turned as well.
https://www.evolutionm.net/forums/sh...=341540&page=5
All the info is on page 5 and 6 of the above thread.
I bench tested it with an air compressor and a pressure gauge. It cracked around 14.0 psi, but I can't gaurantee it's not 13.8 or 14.2 psi, because the gauge resolution isn't fantastic. Pictures and document are in the link I posted above. With a better gauge I can give a more accurate answer.
kimletrim
23
Oct 10, 2006 06:32 PM
Sap12687
Jun 29, 2005 09:39 PM
