BVP EVO X 11.4 @ 114 mph
Old May 16, 2008 | 08:26 AM
mikeHmikE's Avatar
awesome times! keep it up
Old May 16, 2008 | 08:38 AM
sonicteam120's Avatar
ahw man i think you can hit 10's 11.4 is close to it was the interior still in the car congradulation's
Old May 16, 2008 | 08:48 AM
Mitchubishievo's Avatar
That's sickly fast congrats!
Old May 16, 2008 | 08:49 AM
DRAG's Avatar
Nice runs guys! That shift to 5th looks like it is killing a few mph. I am working with one of my sponsors on my Honda for a longer gearset for the X. I need to get some opinions on what people would like to see out of 4th gear.
Old May 16, 2008 | 08:56 AM
Noize's Avatar
EvoM Administrator
Would an IX final drive not work? Seems like it could cure everything if it will fit. I don't know, though, with the changes in the box size, reverse setup, etc.
Old May 16, 2008 | 09:09 AM
Phalse's Avatar
why does that et/trap relation seems so out of whack.. ive seen really good ratios close to that with absolutely brutal .60s like high 1.4x, and shifting that is far from slow, but that just doesnt seem right.
Old May 16, 2008 | 09:17 AM
Noize's Avatar
EvoM Administrator
Its the gearing. Why won't anyone listen to that?
There is no flash tool to raise the rev limit above 7500 yet. This means that the car will only attain 111mph on the rev limiter in fourth gear. An IX at 7800rpm (typical flashed limiter) will do 119mph. An VIII at 7800rpm (typical flashed limiter) will do 126mph.
If you shift to fifth gear, your trap suffers. If you hold fourth, your trap suffers.
Old May 16, 2008 | 09:18 AM
BigValley's Avatar
Originally Posted by Tarmacisback69
nitrous?
Of course NOT. The miles would be higher.
We'll be at Bislo racetrack tonight, everybody is welcome to come and inspect the car. Hopefully after fixing some bugs will do better tonight.
The car is runing 26 psi but in 5th gear we're having problems with the limp mode.
Old May 16, 2008 | 09:21 AM
evovin's Avatar
Nice!!!
So BVP doesn't tune Evo X? Who is Gladiel?
Old May 16, 2008 | 09:23 AM
Jrod@Buschur's Avatar
Congrats guys!
How is that FMIC working out for you?
Old May 16, 2008 | 09:34 AM
socalevox's Avatar
dam sweet times, dam and once u put like cams and stuff in the engine its going to be sick
Old May 16, 2008 | 09:39 AM
SparkTech's Avatar
Congrats guys...you keep upping the bar
Old May 16, 2008 | 11:37 AM
TURBODAWG's Avatar
That is an awesome time for that mph. Definitely making the most use of the power you have. They will definitely need more power (ie. MPH) to get 10.99 . Now everyone knows that a good 60' can be obtained in the porker Evo X.
Any weight reduction other than getting rid of heavier stock exhaust parts?
Brian
Brian
Old May 16, 2008 | 11:43 AM
BigValley's Avatar
Originally Posted by Jrod@Buschur
Congrats guys!
Amazing , the fabrication and quality is unbeleivable and the product speaks by itself. perfect fit and 150% improvement. What else can I say , you guys rock and sure know what you're doing.
Thanks Jrod for taking care of us. I really appreciate it my friend.
Victor
Old May 16, 2008 | 12:37 PM
Tunerhead's Avatar
Very good time man! Been hearing good things about those Forced Performance turbo's.
Quick Reply: BVP EVO X 11.4 @ 114 mph
