BVP EVO X 11.4 @ 114 mph
#31
https://www.evolutionm.net/forums/sh...d.php?t=254995
#33
1 Post
Please read this thread and feel free to comment.
Thanks for the info man!
#36
You are looking at it wrong. low ET coupled with low MPH means either really good 60ft or fantastic no lift shifting or both. I have driven this car. I drove it the day after they broke into the 11s. It felt like a 13 flat car to me. I am amazed at the times they are getting out of the power they are making. The MPH is a direct indication of the power they are making. When they went 11.99 at 110 Bushurs 10 was going 12.7 at 111 mph. Both setups were at about the same power.
#39
Its the gearing. Why won't anyone listen to that?
There is no flash tool to raise the rev limit above 7500 yet. This means that the car will only attain 111mph on the rev limiter in fourth gear. An IX at 7800rpm (typical flashed limiter) will do 119mph. An VIII at 7800rpm (typical flashed limiter) will do 126mph.
If you shift to fifth gear, your trap suffers. If you hold fourth, your trap suffers.
