AEM Water Injection For The X 29 PSI On 91 Pump Gas
#125
it depends on the meth kit installed. some can handle 100% meth some cant. as far as i know snow performance can handle 100% meth. as far as the aem kit goes it says on its website up to 50%. see link if you wanna continue using 100% just make sure you check it regularly for leaks.
#128
I was looking at the install for the aem injection kit and was wondering where these 2 wires go?
Green wire, Boost-Safe output for timing retard or boost dump solenoid. 1.7a Max
Blue wire (opt) 0-5vdc pressure signal. (.328v = 0psig, 5vdc = 38psig)
