Which Intake to get????
#46
If their other product lines are any indication, you'll also be able to get just the intake without the airbox.
#51
Our intake was designed with the aim at maximum possible performance, and as a result has several unique features that can easily be overlooked
The intake piping itself is designed from a single mandrel bent piece for the best possible flow. Additionally the BOV recirc enters the intake stream nearly parallel to the flow direction, again for maximum flow and minimum restriction.
The MAF adapter is machined by hand by our talented team and offers not only a super large 5" K+N filter inlet diameter, but also super smooth transition to flush fitment with the MAF pipe inlet. It also includes dowel pin locating hole for an OEM quality installation.
The entire system is braced against the chassis so movement is limited and rubbing and vibration are eliminated.
We also locate the filter as far toward the ducting behind the headlight as possible for maximum incoming airflow.
More info is available on our site here, but definitely don't hesitate to get a hold of me with any questions! - http://www.extremeturbosystems.com/M...duct_info.html
Tom
Tom
#52
I like how the ETS is all mandrel bent. Anything with a weld is going to cause some tubulent airflow compared to one without. I dont care how good welding skills are. it will not be as smooth and will cause turbulent airflow The more laminar the flow of air is the more air that gets where it needs to be.. turbulent air=bad flow. You can say what u want about weight saving material, but u get an intake to flow better not save a ton of weight.
#53
I have a drop in using the stock airbox; I've even considered going back to a paper filter to see if there is a difference. To me, you should set your AFRs through good tuning, not use an intake that will injest hot underhood air.
I went 11s with the stock airbox and Mitsu paper filter in my VIII, and this one looks to be an even straighter shot than that one.
If you want to go faster, your money is best spent on a tune, then exhaust mods next IMO.
#54
I'm personally waiting for the HKS RS. It was one of the best on VIII's and IX's so I'm sure the X won't disappoint. The only bad thing about that intake is it's filtering ability. I never had any issues though.
