ACT 6 Puck street/race clutch question
Ok so I got the Act 6 puck street/race clutch installed in my car. Rated at 537 lbs of torque. I finaly broke in the clutch so I punched it and when i went to speed shift from 1 to 2 and 2 to 3 it make like a duuuuuuuf sound coming from the clutch. Like it is hitting the clutch hard. Every time I shift normal it drives like normal. So i just wanted to no if this is normal for this clutch do act like this.
Also on a side note everytime i let go of that gas there is this annoying vibration sounds like it is coming from the dash. This happeneing to any one else.
The question that Mike at RRE asked still has not been answered. Is it a solid hub or sprung hub. FWIW any puck disc will have harsher engagement than a full face organic disc. A sprung disc however will dampen the vibration you are feeling but not all of it. The vibration (assuming all is well with the installation) is coming from the gear noise in the transmission. The lack of springs or the use of stiffer springs (like we use) can magnify the noise.
We sell and market all of our puck discs as "race discs" because of the noise and harsh engagement associated with them and we clearly state the potential drawbacks to using them on our website.
mike@roadraceengineering.com to set up a time.
Back to the noise on decell, you are just hearing all the gear slop and lash between all the gears from the transmission, transfer case and rear diff. The stock clutch has giant cushy springs to isolate the noise (and power) between the motor and transmission. On decell the pulsing of your 4 cylinders slowing the car a bit is kicking back against the gears a tiny bit. The same is there always, you just hear it now if you have a stiffer sprung clutch disc. ESPECIALLY if you have a solid hub disc.
Stock EVO disc with big soft sloppy springs
ACT Disc with manly man springs
Mike W
http://cgi.ebay.com/ebaymotors/ACT-C...m200202845474&
Is there any way i can get a direct number to you so i can explain better whats going on over the phone. Thanks.
As for the nozie i am hearing under the dash i think it might have somthing to do with this :
https://www.evolutionm.net/forums/sh...d.php?t=352440
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
-Joe
