EVO X PWR Radiator Info/ Pics
Hello all,
First of all, I just wanted to thank Charles@ PWR for taking care of this, and getting this in the works very quickly.
This is for all you hardcore track addicts...
This is the 1st in the US
PWR Evo X OEM Replacement Radiator
MSRP - $629.00
6-8 weeks before they will be ready to go
Pics.
^ oem fans, and hoses all bolt right up, making this a complete bolt on radiator.
** Will have installed pics, in a few days **
Thanks guys,
Chris
MSRP - $629.00
Pics.
Thanks guys,
Chris
Last edited by Noize; Aug 7, 2008 at 06:42 AM. Reason: removed direct advertising contact info
No one knows yet... no one has the power nor has beat the **** outta the X yet on a blistering hot summer track day w/ an ample amount of horsepower.
Power ranges at the track so far is somewhere between 275 ish to around 350 whp, maybe 1-2 in the low 400 range. (that actually track there car) and not Dyno queens.
I am going to "assume" the stock radiator will be sufficient to a certain point, but this is just a little insurance to me. Some may like it, others may not.
-Chris
-Chris
LOL, I am no vendor... Nor am I trying to sell something here.
I am an EVO X Owner, letting the EVO X Community know about a product I took my time to help get developed and into production.
There is a difference.
-Antics22
Call Charles @ PWR for more information, it's Thicker but I believe the Length and Height are almost the exact same
PWR vs Koyo....
That's a good question, I used both, and never a problem with any.
-Chris
-Antics22
PWR vs Koyo....
-Chris
-Chris
-Chris
Thanks for posting the info, I just wish I could get one sooner, Im at Road Atlanta this weekend and its soooo hot here Anyone know how to get one sooner?
Ryan
You can try runing 2 bottles of Redline water wetter with 100% water mix to get a little more cooling out of the stock setup. Seems like that all aluminum radiator would be good insurance expecially once you start bolting up a thicker front mount intercooler that blocks a little more airflow. It's also possible that if you run higher boost for 20 min+ on the track that you are lifting your head slightly under extreme heat and pressure which will cause a similar problem with fluid being pushed out of the cooling system. ARP headstuds usually work well to prevent this situation since the stock head bolts can stretch slightly... this happened on my Eclipse early on and was a real pita to diagnose until it got worse.
