Review: AGP I/C piping and cold air intake
So I just got my AGP piping and CAI installed today. Too bad my ECU didn't show up from Buschur yet, but Dynoflash had to do some custom calibration for my tune for the altitude. Once that comes in (hopefully tomorrow) I will be able to see what kind of differences it makes.
Review:
I went with these kits from AGP for several reasons. The intercooler piping kit is the cheapest on the market, selling for only $350 which includes both the upper and lower intercooler pipes. (compare that to 250 for just the upper). Both must be installed at the same time, as they relocate the BOV to the hotpipe. The upper I/C pipe is equivalent to any other kit, all the bends are the same, and it's standard 2.5". The Lower I/C pipe larger,, measuring at 3". Since i'm still using the stock intercooler, they supplied a 2.5" -> 3" adapter.
The Intake kit is the only kit on the market that relocates the filter in the wheel well. I decided to go with this route because the price was equivalent to non-CAI intakes ($280), and carrito.net claimed 10whp gain when they migrated their filter to the wheel well. I have had CAI intakes in the wheel well on previous cars, and never had a problem with water. My big gripe is the kit did not come with a splash guard for the intake (as many other CAI systems in wheel wells do), but I still have one at my parents house from my old car, so I will grab that next time I'm at their house. This kit is awesome because it's in two pieces, so if i end up having problems with water, I can remove one half of the piping and have a standard intake in the engine bay (although i'd have to use the stock MAF housing).
Installation had a couple issues, both pipes screw into the stock locations. However, I had to unbolt the lower I/C pipe bracket, with the bolt in I couldn't get my bumper back on. The larger diameter caused the bumper to rub against the pipe at one spot, meaning it wouldn't line back up properly. Once i unbolted the lower i/c pipe, i was able to push the bumper in, and line up all the screws. It looks like the bracket to hold the i/c on was slightly the wrong angle, causing it to sit too far out.
The intake relocates the filter in the wheel well. The only problem with install was with the lower i/c pipe in, the two pipes were rubbing. I fixed this by adding a couple washers to the intake brace. This gave the intake tube enough clearance to not rub against the lower i/c pipe. I'm guessing this was also due to the lower i/c pipe not fitting exactly the way it should. I did this all at the same time, since I wanted to avoid removing the bumper multiple times. However, you might be able to install the air filter without taking the bumper off, but it would be tough.
Fit and finish were very good. All welds are clean, and all parts showed up bubblewrapped so as to avoid scratching. However there were no installation instructions included in the packaging, and I could not find anything on their website. Although i didn't really need them, it only took a couple tries to figure out which tube attached where.
For the time being, i left the plastic cover on the air scoop on the driver's foglight, i need to find some mesh to replace it, so the intake can really breathe. Has anyone found a replacement? I hate having one "fake" air scoop.
Shipping was fast, $66 for two-day air for both parts. All together, cost was 696.37 with delivery.
In summary, it's a cheaper alternative to other competeter's products, and the issues with the lower i/c pipe bracket may be why.
I will post pics tomorrow.
Review:
Sweet thx I've been looking for this.
ETS Michael
ExtremeTurboSystems.com – WA
16
Jul 10, 2012 11:02 PM
AWDTerror
Jun 6, 2011 09:40 PM
Fourdoor
10
Oct 12, 2009 02:28 PM
agp, air, apg, cai, cold, evo, install, installation, instructions, intake, intercooler, lower, pipe, piping, review
