Evo X + C16 full time
Alright I had a question, I was wondering if anyone was daily driving on C16 in an Evo X and if they had any problems running C16 full time. Also if you are running on C16 full time have you adjusted your boost higher for the added horsepower since you don't have to worry about detonation say maybe going from 22 up to about 25-26psi and adjusting the WGA to hold closer to 20psi at redline?
The reason I ask is because I'm about to move for a while to a city where they only have 91 and I dread the thought of running 91...I can either carry around a few gallons of C16 at the house to mix 1-2 gallons per tank in and be equivalent to running 93-94 but with the hassle of going to add it everytime I fill up back at the house or spend a marginal amount more since a tank lasts a while when I'm in school and just running on C16 full time and not having to hassle with going home everytime to add race gas to bring up the octane rating enough for me to be comfortable running it. The altitude is about 3500ft if that matters to anyone. The price difference is about 1.5 times as much to run on C16 full time instead of just 91.
Thanks ~Trent
Thanks ~Trent
where the heck are you buying c16 for $6.00 - $7.00 per gallon??? (1.5 x ga 93)
You are much better off to get a tune for whatever fuel you have available. I promise that with a tune for 91 you will make more power than you are now if you are not tuned.
Another option is NOS octane booster, we normally don't use or reccommend these type products but we have seen this one work first hand on the dyno after some guys wife filled up his 335i with 87 octane.
Just add one bottle to a tank of 91 and you should be fine.
Any leaded fuel will kill a cat that is true, but more important is that it will kill your O2 sensors. You can replace the cat with a test pipe but when your front 02 sensor goes the car will run like complete **** and you will have to replace it.
To expand on what the others have said, running a race gas full time is really not practical. When I lived in FL I worked about five miles from a VP station in Fort Lauderdale that sold race gas. We would buy C16 and C10 (I think it was C10, it was the 100 oct unleaded) for our race cars, and would also run the cars on the street, etc. I had/have a small pickup daily driver that I drove to work every day, and we used to buy the fuel in in 55 gallon drums. Even working that close to the station and buying 55 gallons at a time was not practical to run it on the street. We would empty the drums real fast, and then we would have to plan to buy more. Planning wasn't the problem, the problem was actually making it to the station at the planned time, when schedule conflicts would arise a work, home life, etc.
I would look into either running the NOS additive or running a DIY toluene or xylene mix.
I'm not worried about killing the cat since I don't have one on the car presently...the 02's however would be a problem.
I need to check the pricing on the Torco and similar products to see how much that is per bottle to justify if it's cheaper running Torco per tank or just running a mix of C16 or pure C16. The biggest thing is it would be maybe $20 more per tank to run straight C16 at the price I found plus the convenience of not having to keep Torco or race fuel stocked up around the house to add per tank of gas. I could just go fill up.
When I called the company that sells it yesterday I didn't ask about anything other than C16 but could check on their prices/availability of lower octane fuels as well when I get up there.
I might be wrong but 100 octane would still be leaded and therefore would still kill the O2's I thought...if it's unleaded and I could find it I would definately not object to running 100 octane especially if its cheaper then C16 and won't hurt anything.
John
