FP Red Tuned
Old Nov 19, 2008, 04:47 PM
  #61
gsr0801's Avatar
The tuner told me to get one. Now you so I'll try one.
Old Nov 19, 2008, 06:56 PM
  #62
Show286's Avatar
Originally Posted by griffeyr
I honestly don't know....When the car was tuned it did 336 hp and 325 tq @ 21.69 psi
I went back, and added the fp red, 880's, buschur ported manifold, epm 02 dump, and retuned to about 23 psi and got 370 hp 360 tq
So something is def. off
How far apart was this done? I know about year and half ago there dyno read very close in HP to a local dynojet the TQ on the other hand was way off.
Old Nov 19, 2008, 07:01 PM
  #63
griffeyr's Avatar
tune was done 1 year 4 months apart
Old Nov 19, 2008, 09:17 PM
  #64
spdracerut's Avatar
Originally Posted by gsr0801
At 30psi on pump gas and meth, I'm maiking well over 510whp but which is not good because I have a stock block. The tuner didn't want to full tune it because the boost couldn't be control. I spoke to Force Performance and they told me the check my 02 housing or to port out the turbo.
You could also try adjusting your wastegate actuator first. If you have the adjustable rod too far out (i.e. actuator pre-loaded too much), the flapper won't be able to open far enough to bleed off the boost. If you go as far as to take off the turbo, port out the wastegate port as much as you can.
Old Nov 21, 2008, 10:33 AM
  #65
Sully 18's Avatar
what boost controller do u have...
i had the same problem and i switched to a hallman pro rx
Old Nov 21, 2008, 03:17 PM
  #66
gsr0801's Avatar
I'm using the forge MBC. I heard porting out the turbo exhaust turbine housing is better than an 02 dump on the FP RED to ger rid of boost creep.
Old Nov 21, 2008, 03:22 PM
  #67
Jeffs2006EVOIX's Avatar
your post
I want that TURBO BAD!!! haha.......the FP Red is the BOMB. Anyway, yes, get the head studs and you will break the 400whp no problem. That is my goal 400whp daily driven Evo IX. Saving for the Red Now. Would of had it by now but the seperation from my wife wiped me out. Was lucky to get out with my Evo, haha.
Old Nov 22, 2008, 01:26 PM
  #68
HxllxMan's Avatar
compare to a X and same dyno on pump with basic bolt on.
how much both car made in average?
Old Nov 22, 2008, 02:12 PM
  #69
griffeyr's Avatar
anybody with a x wanna chime in on this???
Old Nov 25, 2008, 03:21 AM
  #70
AlphaKennyBody's Avatar
272 Cams, TBE, Injectors and Pump and Ebay FMIC and MBC set to 2x something psi I dunno but my friend with his Red dyno 495 on 91 pump.... On top of that it was 100 degree weather
I know they wanted to turn the boost up but to run it over 30+ psi he needed Studs. So Your numbers seem to be way off... Bring it to another shop and see what it dynos.
JScocchio
Mar 21, 2013 06:28 PM
vmrevo9
Sep 5, 2012 05:58 PM
greatgonzer
Jan 1, 2010 09:53 AM
Hiboost
Evo X Dyno Results
Mar 20, 2009 06:30 AM
Sapperhustler
22
Feb 2, 2007 05:01 PM
Quick Reply: FP Red Tuned
