AMS How to build a bullet proof 4b11 Part 2.
I think it's funny how every generation of Evo, guys on this forum ***** and complain about the changes made in one way or another. I've watched guys on this forum doin it since the 7 when I first joined. Most recently, at least 80% of the guys on this forum complained about Mitsu coming out with the 4b11 crying that it wouldn't live up to the prehistoric 4g63. Good job AMS for showing the whiny little girls that it wouldn't take long at all for some serious internal bullet-proofing. You'd think it would be the old farts being afraid of change but that's not the case. Again, great job AMS!!!
Hey MR. Mean Sir, whenever something new comes along, people will ask is it better than the last model. Nothing wrong with this; just a "show me"attitude. NOthing more, nothing less! Ease up big fella.
Later, Ken
Later, Ken
OT: But I remember making that classic quote! Thanks for keeping it alive!!!
Yup Tim, they are definitely larger! So the aluminum is lighter but not as strong, therefore, the need for increased thickness all around. So how does one determine the benefits of going aluminum vs steel? Is the weight a wash between the two and if so what is the advantage then of going to aluminum? Just curious here.
Later, Ken
Later, Ken
Aluminum Rods have a relatively short term life!
I think using Aluminum Rods is a proper thing for you to do, to be able to build your test 4B11 motor in a shorter time, and they will take a tremendous amount of punishment for a long enough period of time to give you the information you need now.
For a long term solution I think you will agree that a billet steel rod or a forged steel rod, which would take much longer to produce, is a much more appropriate long term choice.
As you said proper maintenance (replacing the Aluminum Rods with-in their known Life cycle) is key in the success of running a motor with aluminum rods that are relatively cheaper and faster to make. -
Aluminum Rod Alloy
Not absolutely sure about the alloy, but I would guess it would have to be something close to a forged 7075 alloy to get the strength needed for a "Rod" application.
Later, Ken
Later, Ken
He said that he needed a custom length, so it was much faster to have the aluminum rods made. It usually takes us 2-3 weeks to get a custom length rod in aluminum, and I think I waited several months for my steel rods to be made.
Also the aluminum rod is forgiving and can absorb some shock in the case of preignition or other stressing conditions.
Also FWIW, we have tried everything we can to get weight out of the bottom end and really have never picked up ET on any motor with lightweight block components, but see big gains lightening valvetrain.
Less Friction at the Threads!
The benefit in using after market Head Studs is the reduction of friction at the threads. The relatively much longer thread at the end of the Stock "Head Bolt" has a relatively much higher friction value when torquing the "Head Bolt" during installation than when the "Nut" on an after market "Head Stud" assembly is torqued during installation. This reduction in friction translates into higher clamping forces applied to the Head to Block interface because less torquing energy (clamping force) is lost to friction at the threads.
Also the aftermarket "Head Studs" are of a higher tensile strength and therefore stretch less under full boost thus maintaining a higher clamping force.
Another advantage using after market “Head Studs” is less wear and tear on the threads in the Aluminum Block because the studs are only put in once even though the Head may be R&R’d many times.
As far as increasing the stock specified torque value, when using after market “Head Studs”, I would guess that most engine builders here may only go up 5 lb. ft. over the stock specification. Not being an expert on the 4B11 Motor I would be interested to know if my assumption is correct about this.
So in short to answer your question – no the threads in the aluminum 4B11 block are not at risk of being stripped out when using after market “Head Studs”.
Hope this helps your understanding of the benefits of using after market “Head Studs” -
AutoMotoSports
Jan 27, 2010 09:15 PM
AutoMotoSports
71
Oct 7, 2009 03:37 AM
Tim@AMSperformance
Automotosports - Illinois
39
Sep 17, 2009 05:37 PM
AutoMotoSports
73
May 11, 2009 07:52 AM
