Has anyone blown a motor
#31
I am not saying its either person's fault. I am merely asking how can you infer its one person's fault or the other without seeing the engine itself or building the engine yourself? You are making invalid assumptions because you have not seen a thing.
EVERY manufacturer builds engines that go boom at no fault to the user. That is FACT. Yes, even your precious Evo can be built incorrectly. Shocking, I know.
Edit: Also, just curious, in your earlier post you say it was from a "high rev", how high of an RPM do you consider too high on the Evo X?
#32
#34
Alright dude say what you want, fact is, I think the guy who blew his motor up is stupid, I think this because he probably abused, now I don't know for sure, but only what others who know him more then me, have told me. So frankly I don't give a crap. My EVO runs/drives great. That is all that I care about. I am done here. If you think I am making claims, well whatever, I said what I said and no point in arguing what you don't know. Cuz frankly I don't know alot about these cars, all I do know is this person blew his motor and what the tech at mitsu dealer told me, so I think it is stupid. End of story....
#36
I will answer it sure. past 7k when it is new, will hurt the motor before break in, I would think, but I really don't, knowing the properties of metal and a block that is sleeved, high rpm prior to piston rings being wore in would cause damage, I can only speak for what I have seen in V8's and well this is no v8 so I don't know, but anyway. I am just busting your *****, no hard feelings I hope, I know your screen name cuz I know you blew your motor at 3k and I personally saw your clutch, so you where HARD on it. BTW, if you still don't know who I am just walk into the control center, you will know what I mean.
Edit: I only starting saying you where stupid and an idiot when I saw your screen name just to see what you would say. I think you are alright, just hard on cars.
BTW: You don't have you side step my question I already know, you blew your motor.
#37
And like I said. You don't have the facts. I do. I have pictures of ****, and I KNOW what caused my engine failure. Just because you drive a car hard, doesn't mean it will hurt the engine. If it were dangerous to rev to 7600 (the stock rev limiter), then the mitsu engineers would have set the limit lower. I didn't void the warranty, hence, Mitsubishi has no grounds to stand on denying my claim. I have lawyers to back me up as well, I promise you there is a reason they didn't deny my claim.
#38
Easy....... that is cool David, like I said before, I think it is awesome that mitsu hooked you up, and again, I am just repeating what the evo tech told me, he thought you were running NOS. And I just when he said that. Sorry if I came across as a dick, wasn't trying to be, just giving you some crap cuz you blew your motor or mitsu blew your motor whichever way you look at it.
#39
1. Break-in procedures can always be 100% debated.
2. Any engine can be blown, especially when leaned out.
3. High RPM's will not blow a motor that's built for it, but high RPM's *will* wear down components faster than the same engine not redlined all of the time.
4. Cracks in pistons (like pictured) come from excessive heat (ran too lean). Ringlands CRACKING (but not melting) comes from excessive horsepower for a given set of pistons.
- Louis
- Louis
#40
i know a few X's here in PR broken by owner/driver mistakes and overboost...
i know an instance of 2 x's breaking at the same day (racing) because of overboost
theres a guy here w/ a white one (pepe colon's son for those who know pr folk) he is on his 3rd going on 4th engine already...
common failure comes from the piston 'skirt' cracking under boost
#41
that detail i dont have....
but on my car im running a dangerous spike and i cant seem to fix it either by programming or unscrewing the wga.... is spiking to 28~30 then dropping to 19~20, this is not normal obviously...
wot skipe of almost 30psi is dangerous on any car i dont care how safe the afr is
#42
I remember a failed 4B11 just after the car was released. The car had ~500 miles on it, no abuse. They were searching for a new block...at that time which is why I remember. It was pretty much a lost cause, I don't even wana see the bill for that from Mitsu.
#43
We lent our shop X to a customer who apparently shifted from 2nd to 1st and a pin in the MIVEC gear sheared off and as a result the pistons tagged all the valves and one of the pistons cracked.
We simply installed new valves and a set of Buschur pistons which have been really amazing
Al
Al
dipsetinallday
Feb 5, 2010 12:21 AM
