testpipe queation please help
i did search but did not get the answer i was looking for ,so i am asking the experienced for advise.... i am looking at testpipes but do not want a cel. which ones do not throw a cell and what can i do to make one not throw a cel?
i have been looking at ams,ets,and ur.
any sound changes with the ur resonated pipe? when i was tuned i was told i had some restiction up top which ams said could be the cat since they see this issue with all catted evox's. i was told a test pipe or high flow cat would help the issue. dp was also thrown into the mix as a restiction.
https://www.evolutionm.net/forums/ev...ipe-evo-x.html
(Scroll down half way).
Get a 90 bend o2 sensor from Touge Factory. (Scroll down half way).
I have T1R with Touge Factory spacer. No CEL
You will potential get CEL with almost any type of test pipes without an type of spacer/o2 fouler on it. Some will get CEL very early and some will not. Hell even with a spacer, you can potential get CEL cause its not stock.
To prevent CEL you can get a spacer of some sort. the 90 bend will be the best bet to prevent CEL. I have it and i have yet to get CEL. I know alot of VW, audi guy who run 90 spacers. They call them "Wayne Angle Block".
^ talk to Touge Factory, they sell angle blocks.
Add another for the ultimate racing test pipes. I have the mini muffler test pipe. Noise has the Resonated test pipe. Neither will throw a CEL, both are louder than stock, both make power.
AMS is correct. catted X's have to be tuned softer up top the keep the knock activity down. Also have to be tuned richer to keep the cat from dying.
fengzhaoxi
Jun 18, 2010 11:14 AM
