Test pipe = less engine braking?
I had a high flow cat but stumbled upon a test pipe, so I'm playing with it to see if it makes a LOT of difference (the jury is still out). It sure smells worse and is much louder in the cabin though.
When I crest hills in traffic, I let off the gas in case there's a cop with a laser and with the high flow cat (or stock no flow cat), when I let off the gas the car would decelerate a decent amount (3-4 mph) just from engine braking. Going down the ramp in the parking garage at work I'd slow down a bit too.
Now, it feels more like an automatic and the car seems to coast more, not slowing down as much.
Is this everyone else's experience?
Ive got a HFC and even when I was stock, letting off the gas to decel seems the exact same. It almost seems like it kept on cruising as if I hadnt let off the peddle until a few moments later (20-30 seconds) it finally kicked off and started to decel me. I just attributed it to the drive by wire.
That's a magical test pipe! No idea why that would happen, I can tell you from testing my friend vs me who had the same set ups just one with test pipe and one with HFC I had about 10-12 more hp than him, but that was on an VIII with the older less-flowing high-flows. The newer ones supposedly flow almost as well as a test pipe.
But off throttle I can't think of why it would be different... Back pressure maybe?
I get the rev hang more often when im backing up and just creeping back, but it seems to want to rev higher for a couple seconds even after taking my foot off the gas and clutching in.
Best response so far was your own.
Honestly though, it probably doesn't pollute "that" much. I had the test pipe in my 8 (so none of the fancy 21st tech keeping my fuel system clean ) and they ran the old fashioned sniff test on the car. I passed. I was on the high end of the passing range, but I still passed within Utah limits. So much so that they got confused and had a hard time trying to find my "cat" for the visual inspection part.
I think the guy commented that I polluted about as bad as a car from the 80s?
It should be slowing less because of the backpressure man. I noticed mine is better than stock cat vs test pipe. Also alot less engine breaking I noticed running with ASC off during normal decel. I still have a little hump at about 3400rpm that it really slows from there down
razorlab
40
Mar 10, 2008 11:19 PM
